lexatola
Sep 17 2014, 10:14 PM
Hello all - I'm brand new to this forum with my first post! I've got other Porsches but just purchased my first 914. I picked up a 1970 with a 1.8 motor with dual weber 40 IDF Carbs.
I've been researching motors and see that the 2270 is a very popular upgrade. I love everything I've read about it - thinking about the kit from the type 4 store.
So what work would need to happen to the 1.8 in order to make this happen?
Will the Weber 40s work for induction or will this build require 44s?
Are there other tried and true builds that could be put together from known parts for less money?
I'm just trying to figure out the best way to build a cost effective motor that will make the car go and last....
Love to hear opinions,
Alex
Johny Blackstain
Sep 18 2014, 07:26 AM
I'm hardly an expert but I believe it's all relative to what you want to do with the car- daily driver, track car, full restoration (probably not the latter since your looking to upgrade). The 2270 is extremely popular & the man who invented it is a regular on this forum & will have 99.9% of the answers you're looking for regarding it. I'm not sure but I think that dual 40mm Weber downdrafts are NLA & might be worth some coin on the used market. From what little experience I have on the subject, it seems the 40's are more for street use over the 44's.
Bob L.
Sep 18 2014, 11:19 AM
I'm no expert either, from what I have read, going 2270 would probably require the 44's. Going with the stroker crank might also require some machining inside the case for clearance.
larryM
Sep 18 2014, 11:34 AM
QUOTE(lexatola @ Sep 17 2014, 09:14 PM)
Alex
the answer is in this book - get it
Tomlinson weber manual
rhodyguy
Sep 18 2014, 11:49 AM
it is my understanding that to fully realize the hp potential in a 2270, heat exchangers aren't going to cut it and you'll spend $$$ while leaving hp on the table. the owners i know with that displacement run header systems. a 1911 or sourcing the components for 2056 (find a good core and use your current engine til the build is done) should provide a pleasant increase in power and the monetary dif can be applied to other areas of the car. living in the pnw you'll miss a warm interior and hate a foggy windshield. how much hp and torque do you think you need?
horizontally-opposed
Sep 18 2014, 12:06 PM
2056 with carbs or FI is supposed to be a really nice package.
Beware the 914-4 owner's quest for more power...it seems to lead to six cylinders an $$,$$$ all too often. Ask me how I know...
pete
lexatola
Sep 18 2014, 03:21 PM
Thanks for the various responses. I'm looking to restore this car to largely original cosmetics. I'd like to keep it narrow, add a nice set of 15" Fuchs. Tighten up the suspension and add a bunch of HP and Torque and have it be a great tear around street car. I have an Emory 356 outlaw that makes about 120hp but the car only comes in at about 1,600lbs. I figure the 914 will need to make around 150hp to be comparable. I like the 2270 because of its torque. My other cars are all high revers. This would be something different.
Best,
Alex
rhodyguy
Sep 18 2014, 03:26 PM
btw. welcome to 914world!
Sep 18 2014, 03:35 PM
QUOTE(lexatola @ Sep 18 2014, 02:21 PM)
Best,
Alex
Welcome to 914world, and the world of Porsche's "other" genius.
I was looking for exactly the setup you are, and was sabotaged just before pressing go by a high-school friend's offer to help me convert my car to a six. Doing a 2270 to 150~ hp right isn't cheap, as I discovered, so I went with a rebuilt 2.2 six with (nice) used parts and a mix of NOS and aftermarket parts. It was about a wash when I started in 2010. Not so much now, I bet—though I hear good Type IV parts are getting hard to find.
I too like the Type IV for its torque (and, especially) its low weight. That said, I've got no regrets. Your mileage may vary, and you'll have the car I wanted if you stick to your plan.
Enjoy!
pete
blackmoon
Sep 18 2014, 03:41 PM
I did a lot of research before I made the plunge, I went with the 2270 kit from Jake Raby with twin 45 dellortos and very happy with my build. Lots of torque and a good daily driver
Bleyseng
Sep 19 2014, 08:43 AM
Alex
Let's meet up and I'll let you drive my 2056 w/Raby cam, Djet and still has stock heat for the NW's cold days. That will let you decide how much HP you need.
Geoff
914work
Sep 19 2014, 09:58 AM
Alex,
take Geoff up on his offer ...& come swing by my place (Mill Creek area)
Phoenix914
Sep 19 2014, 10:07 AM
Why do I have to be the one to say this?
Ok, really I've always wanted to say it! So there it is.
EdwardBlume
Sep 19 2014, 03:28 PM
It all depends what you want to use the car for. A DD may call for something entirely different from a streetable track car. Then there's cost. If I were starting out, I would put money in suspension and mods with the 1.8 in, and upgrade to a 2056 when someone sells one for a decent price.
Chris H.
Sep 19 2014, 03:48 PM
It might be worth it to check out McMark's turbo setup he installed on the gold car. Seems like a great alternative to a full-on engine build. He was really pleased with it. I think there's a thread somewhere.
lexatola
Sep 19 2014, 04:04 PM
Hey Geoff and 914werke - do you guys ever come down for the Redmond Town Center exotics event? Saturday mornings - It would be a great time to meet up. My 914 is not on the road but I could bring a 356 or bus just for fun!
Lemme know,
Best,
Alex
0396
Sep 19 2014, 06:26 PM
It's an opened ended question. I think it all depends on one's ultimate budget.
flmont
Sep 19 2014, 08:23 PM
You can also read a article on pelican parts about the big four engine under there tech.heading,..its a article from Mr. Nugent that built and ran it as a racer,.??? or look up lite914.com,..Iam in the same boat with a 2.0 ready to build found a shop in hawthorne ca,..Iam going with..European motorworks.
TravisNeff
Sep 19 2014, 08:40 PM
A 2316 is not too much more $$ than a 2270.. Freight Train!
HalfMoon
Sep 19 2014, 10:24 PM
When I toast 5.0 mustangs with my sbc Darkside Teener it gives me a warm and fuzzy feeling.
Come to the Darkside Luke
r_towle
Sep 20 2014, 07:12 AM
If you have an Emory outlaw, you need to look at this motor for the 914.
Www.polomotor.com
The Emory team can help you, they have used this before in their wonderful creations.
