Full Version: 914-6
Grit
Brand new to this site, working on 74 , drilling out the rear hubs and rotors, what size stud is used for this conversion? I can machine them myself but do not have knowledge of stud used...
Wdunster
I believe you need a 14mm drill bit and the factory stud will press in the hole. I did this conversion about 8 years ago.
sixnotfour
you need to spot face the backside ..also, or they be crooked
JFJ914
QUOTE(Grit @ Sep 18 2014, 09:09 PM) *
M14-1.5 x 45mm
oldschool
sled9146
QUOTE(oldschool @ Sep 19 2014, 09:41 AM) *
I have factory Verbus Porsche studs in the following lengths:
45mm
52mm
66mm
100mm
45 and 52 were stock offerings depending on year and wheel. 66 for use with 21mm spacers and 100 for use with spacers
Sled
