QUOTE(Dave_Darling @ Sep 20 2014, 12:11 PM)
That may not fix the problem. The gauge in my wife's SC was like that when we bought the car. The problem was the gauge, not the sender.
I suggest removing the sender, and measuring the resistance across the gauge output. (From "G" to the three-line ground symbol.) Check it with the sender right-side up, and again with it upside down. Someone here will remember the correct range; I think it's on the order of 90 ohms - 0 ohms? Verify that first. If that measures OK, then I would suspect the gauge. See if you can swap with someone else, or pick up a spare. You might be able to borrow one for testing.
--DD
Another good suggestion!
My tank is soon to come out (for a sway bar installation) so I can attack this at the same time :-)
