914-4 Front Brake Discs | ||
Brake disc thickness | 11.0 mm +0.05 -0.15 | .433 in + .002 -.005 |
Min thickness of disc after turning | 10 mm | .395 in |
Wear limit of brake disc (symmetrical wear) | 9.5 mm | .375 in |
Thickness tolerance of brake disc | 0.02 mm max | .0008 in |
Later wobble (deflection) of brake disc installed | 0.2 mm max | .008 in |
914-6 Front Brake Discs | ||
Brake disc thickness | 20 -0.2 mm | .787 - .008 in |
Min thickness of disc after turning | 18.6 mm | .732 in |
Wear limit of brake disc (symmetrical wear) | 18.0 mm | .709 in |
914-4 Rear Brake Discs | ||
Brake disc thickness | 9.5 -.02mm | 374 -.008 in |
Min thickness of disc after turning | 8.9 mm | .351 in |
Wear limit of brake disc (symmetrical wear) | 8.5 mm | .335 in |
Thickness tolerance of brake disc | 0.02 mm | .0008 |
Later wobble (deflection) of brake disc installed | 0.2 mm | .008 |
914-6 Rear Brake Discs | ||
Brake disc thickness | 10.5-0.2 mm | .413 -.088 in |
Min thickness of disc after turning | 9.5 mm | .374 in |
Wear limit of brake disc (symmetrical wear) | 9.0 mm | .354 in |
Thickness tolerance of brake disc | .02 mm | .0008 |
Later wobble (deflection) of brake disc installed | 0.2 mm | .008 in |
QUOTE (Brett W @ Jan 27 2005, 03:16 PM) |
Not thick enough. .433 in I am looking at another option that should be a bolt on upgrade to an .810 vented rotor and a four pot caliper. I'll keep you posted when I have the other parts to compare to. |
