QUOTE (9146986 @ Jan 27 2005, 06:00 PM) |
How 'bout getting the parts from a place that gives tech advice??? Sorry, just had to.... Take the wheel off and remove the cotterpin in the stub axle. Take the hubcap off the wheel and put it back on the car, set the parking brake, and put the car in gear. Put the socket through the hole in the center of the wheel and with much force (I use a 3/4" drive socket & breaker bar with a 8' cheater pipe) unbolt the castelated nuts from the stub axles. Have someone step on the brake pedal, if need be. Remove the wheels, the rear calipers, and the rear rotors. Unbolt the CVs at the transmisson and pull them away from the drive flanges, do not damage the mating surfaces of the drive flanges or CVs. Using a brass drift and a large hammer drive the halfshafts inboard and out of the hub. Unbolt the four screws behind the hubs, that fasten the bearing retainer to the trailing arm. Drive the hub outward with the brass drift, in a circular manner so you don't get the hub cocked in the process. You may need the cup style bearing puller to pull the bearings, but you may be able to drive the bearing out in the same manner as the hub. (if you purchase your parts from some places they will rent a bearing puller tool) You will probably ruin the bearing in the process. This is normal and you should replace the bearing at this point anyway. And our most famous/favorite lines from the venerable Haynes manual "INSTALLATION IS REVERSE OF DISSASEMBLY" Double check all torque specs and make sure you've got everything put back together right. Always use new CV gaskets. I clean the threads (male and female) of the CV bolts before I put them back on. You can use a scant drop of locktite, but don't overdue it!! If you don't know how old your brake fluid is, run new fluid through the system. And remember, the cheapest parts usually come with the lowest level of customer support and technical advice. |
QUOTE |
But then I'm not as cheap as half these whack jobs around here. |
