malcolm2
Sep 28 2014, 02:26 PM
OK, I know enough about elec. to test a few things so here is what I found once home from Okteenerfest.
Fog lights, driving lights, whatever you want to call them just quit working.
The pull knob lights up
I get 12v in the front trunk at the connection from the main harness. (that is with the connection separated) {with all wire connected, I get no reading}
Grounds have continuity there too.
I did not get 12 volts once I took the light apart, not the bulb holder, just the light was apart and I used an alligator clip to ground it. No volts.
If I remove the alligator clip from the hanging light in the picture below and put the red lead of the VM on the white/ylw wire at the bulb holder THEN the black lead of the VM to a bolt on the car..... I get 12 volts.
So with the bulb holder or the complete fixture assembled and grounded I get nothing.
What is going wrong here?
messix
Sep 28 2014, 02:39 PM
is there continuity on the ground of the socket [outer part the bulb fits into] to the ground on the car?
so if you have the light dismounted from the car and you run leads from light mount to car for you get 12V?
if no, check for continuity from socket to mount of light with ohm function on meter [it should read just like if you touch the meter leads together] ?
if no continuity look for why. broken wire? corrosion?
messix
Sep 28 2014, 02:45 PM
is this a sealed beam light?
Tom
Sep 28 2014, 03:06 PM
Sounds like you have a bad/dirty connection that is losing continuity when a load is applied. The meter reads at the socket because the meter is not applying a load, well yes a load but very small. The bulb has a larger load, so the connection breaks down and you get no voltage reading. Check up stream for all connections, ensure they are clean and tight.
Tom
Mike Bellis
Sep 28 2014, 03:07 PM
If you read 12V on the ground lead, through the lamp, with it disconnected from the car, the circuit is good. You may have a really bad ground. Run a ground lead all the way to the battery negative for testing and see if the lamp will light up.
malcolm2
Sep 28 2014, 03:13 PM
QUOTE(messix @ Sep 28 2014, 03:39 PM)
Can only check that when disassembled. The brass spring touches the bulb holder that touches the outer portion of the bulb. Ground runs thru the metal to the brown wire. I have verified continuity from the outer part of the bulb thru this system to a bolt on the car.
Click to view attachmentQUOTE(messix @ Sep 28 2014, 03:39 PM)
NO that is the problem, plus it is both lights not working.
You would think that if you put 12v on the center of the bulb and grounded the outside case of the bulb, the bulb would light up. When I ground it the 12v goes away.
malcolm2
Sep 28 2014, 03:33 PM
QUOTE(Mike Bellis @ Sep 28 2014, 04:07 PM)
I will give that a try now.
BTW this is a 75 with back dated bumpers. I added the fogs last year. The harness in the car had covered connections for this.
Both lights are not working and the bulb I have taken apart has continuity.
Going to find a long wire.
malcolm2
Sep 28 2014, 03:42 PM
OK, the blue wire hanging down is straight from the battery - side. With the black clip on the horn, and the red one on the bulb center, I get 12v. Car is idling and headlights are on LOW, along with the fog knob being pulled out. Then...
Click to view attachmentwith the black clip on the blue from -BATT I get 0.
Click to view attachmentedit: not a symptom anymore
Strangely enough, I do NOT get continuity between the blue wire directly from - BATT to a bolt on the car or the horn...
Dave_Darling
Sep 28 2014, 03:47 PM
QUOTE(malcolm2 @ Sep 28 2014, 02:42 PM)
I'd say that is a pretty big red flag there. Time to start checking all of your grounds. Remember that paint is not a good conductor, so if you're checking on painted parts you may need to wire-brush the paint away.
--DD
malcolm2
Sep 28 2014, 04:51 PM
OK, must have been something in my rig from the batt - to the front of the car. I now get continuity between the blue test wire from batt- and any metal I touch.
Just to be sure I took two test leads at the battery and made the bulb come ON. I was getting continuity, but wanted to see it work.
I have checked around the car and don't see any obvious ground issues. I check continuity with the blue wire all over the car.
So I still show 12v at the bulb when the ground to the bulb is not attached, and 0 when it is.
Mike Bellis
Sep 28 2014, 04:53 PM
If you have 12V to the light, the problem is with the light or a connection, most likely ground. In fact, try a new lamp. On very rare occasions, they can be bad, have continuity and not light up.
malcolm2
Sep 28 2014, 05:00 PM
QUOTE(Mike Bellis @ Sep 28 2014, 05:53 PM)
It lit up with test wires directly to the correct places on the bulb. Both lights, right and left are out.
I have pulled my elec. drawing from Prospero's garage and it does not have driving/fog lights on it. I see no white/yellow wires on this whole drawing.
76-914
Sep 28 2014, 05:03 PM
Look at the bulb carefully to see if the tungsten filament is broke and sometimes making contact. If you tap it slightly you will see if it separates.
76-914
Sep 28 2014, 05:07 PM
messix
Sep 28 2014, 05:09 PM
check and clean contacts on fuse 10
malcolm2
Sep 28 2014, 05:13 PM
QUOTE(76-914 @ Sep 28 2014, 06:03 PM)
I get continuity and I lit it up. Plus both lights are out and went out at the same time. I was hoping to find someone that has the same problem or that could follow my description of the symptoms.
I too feel that it could be related to ground. But, if I place the VM on continuity and one lead on the connector on the brown wire or the flat brass spring, both attached to the fixture and the other VM lead on a non-painted screw and get continuity, wouldn't that rule out that ground wire?
If the + wire( wh/ylw) was touching metal, wouldn't the other stuff in the car being going crazy?
And might I get continuity between the + lamp connection and ground or other non painted metal?
messix
Sep 28 2014, 05:24 PM
do you have amp draw feature on you vom?
if you do set the leads in the proper config, disconnect the hot lead for the light, then connect the leads to the hot wire from the car and then the other to the hot lead of the light and observe to amp load, if there is no load check it at the splice in the trunk, still no load check fuse 10 on the fuse panel.
there is a relay behind the fuse panel and that might be faulty also where it will not supply a loaded circuit.
malcolm2
Sep 28 2014, 05:47 PM
QUOTE(messix @ Sep 28 2014, 06:24 PM)
I don't have AMP draw feature, but I can grab an AMP meter from my guys at work and check it out tomorrow.
You mentioned the relay, and it made me think. I have not upgraded the wiring so the fogs operate only when the headlights are LOW beam. The fogs shut off when you switch to HIGH beam. The relay is probably what does that, so it is acting like the beams are on high.
Driving to Okteenerfest on Saturday morning, it was dark enough for headlights and my HIGH indicator on the dash is not very bright. I think I had my high beams on all morning.
I will search to find which relay and if it is one of the standard ones, I have some spares.
BTW: fuse 10 is clean and tight.... another thing I did with this car is that I have upgraded the fuse box, so it is brand new, 6200 miles.
malcolm2
J5 Is the one. Bowlsby had it.
malcolm2
Sep 29 2014, 06:13 PM
for more conversation and some results.
I have 2 spare relays. I tested them per the picture below: WHile checking continuity between 30 and 87 you put a 12volt power source on either 86 or 85, then you ground or put a batt- on the other. When you touch the relay with the last wire, listen for the relay to click and watch your meter for continuity.
my spare relays and the one I just took out of the fog light spot on the panel under the dash are operating.
So I took a flashlight under and found that 87 could not be doing it's job.
So what would make this melt? Yes heat, but how did it get hot.
I don't want to just get a new relay seat, or rewire and have this happen again.
malcolm2
Sep 29 2014, 06:16 PM
My guess on operation: When turned on and on low beam (OEM design) the relay activates (12v across 86 & 85) coil magnetizes and pulls the arm down to sends 12 volts thru 87.
knob in or high beams on and we have no path from 30 to 87 cause you loose the magnet and the spring opens the circuit and the lights go out.
so the WH/ylw wire comes from 87?
malcolm2
Sep 29 2014, 08:40 PM
One more bump...
No action on electrical issues tonight?
Anyone have ideas on what happened, more to look for, how to fix?
messix
Sep 29 2014, 09:11 PM
corrosion on contacts make a high resistance and cause a high amp load on the circuit melting the relay socket, or some one put in higher wattage bulbs in 35 watt fog light and melted relay socket.
malcolm2
Sep 29 2014, 09:22 PM
QUOTE(messix @ Sep 29 2014, 10:11 PM)
you are referring to contacts within the relay? So the relay could check out, but still be an issue with the heat? I guess I should stick one of the spares in and see what happens.
The bulbs are stock from a 73, I'll have to check, but I am pretty sure they are 35w.
Mike Bellis
Sep 29 2014, 10:18 PM
Most likely cause of the melting was a loose connection at the relay. This causes a micro arc at the terminal heating it up. This is common for this type of relay.
messix
Sep 29 2014, 10:22 PM
QUOTE(malcolm2 @ Sep 29 2014, 08:22 PM)
most likely the relay socket will need to be replaced, all the melted gunk will keep from making a good electrical connection
914Mike
Sep 29 2014, 10:48 PM
Check the pins on your relays. If you look closely you will see the they are actually split into 4. I used an Xacto blade to spread them a little before inserting them to insure good contact. It's also possible to squeeze the rings on the socket a little when they get loose.
malcolm2
Sep 30 2014, 05:49 AM
QUOTE(914Mike @ Sep 29 2014, 11:48 PM)
I did try one of the spare relays and the lights came on.
I will go back and see if I can clean out the relay plug a bit to get the melt out and I will spring the pins too.
If I have to go as far as replacing the plug, does anyone have any recommendations on that?
All the separate relay plugs have different color wires, not that that is too much of an issue, but it would be nice to find a plug with the same color wires. I suppose a complete fuse panel purchase might be in order.
Can't remember if the 2 914 in the JY have fuse panels left in them.
Would these be available new?
Thanks for the suggestions,
Clark
Tom
Sep 30 2014, 06:51 AM
So it was a bad/dirty connection? Seem to remember saying check those in post #4.
Glad you finally found it.
As to exactly why you were reading voltage in post #1, but getting no fog light when you connected them: with no ground hooked to the end of the fog light circuit ( the bulb was not in the circuit and the normal path to ground is thru the bulb to ground) this is an open circuit and all points of the + circuit will read battery voltage. When you hooked the bulb into the circuit, that did make a complete circuit to ground, however, the bad connection at the relay was dropping all or most of the voltage across it instead of across the bulb.
Now, why did the relay socket melt. Power dissipation in a very small area that had no way to deal with the heat. It should have been 0 ohms and then there would be no power dissipation across that connection and no heat build up. Why power dissipation? Because the bad connection was not always so bad (high ohms across the connection). When it was a lower ohms connection, say 1 or 2 ohms, it was causing 36 watts at 1 ohm and 18 watts at 2 ohms to dissipate in that small area. As the heat built up, the connection rapidly failed to a much higher resistance due to the heat causing oxidation and plastic/rubber contamination and possible arcing resulting in even more heat.
That's why I said in post #4 Check up stream for all connections, ensure they are clean and tight.
Well, that's my story anyway,
Tom
malcolm2
Sep 30 2014, 02:10 PM
QUOTE(Tom @ Sep 30 2014, 07:51 AM)
Tom
My limited experience with voltage left me not thinking of the relay as a connection. So in my mind, there were no more connections from the harness in the front trunk to the relay. All of those had been checked.
So I planned to eventually drop the fuse panel and check the connections on the switch, still not thinking of the relay as a connection. But I did know the relay was a possible failure point.
Well it obviously is a connection, something that I will look at sooner next time for sure. I'll put my hands on this in an hour or so and see if I can make good tight connections at that lightly melted plug. Fingers are crossed!
UPDATE: cleaned the brittle rubber or plastic from the melt, pinched the "rings" on the socket that connect to the relay and I spread the pins in the relay. Also used some emory cloth and cleaned the pins and the inside of the relay socket rings. Put my light back together and turned it all on. Hit the high beams 10 or 12 times and everything is working fine.Thanks again.
