hndyhrr
Sep 29 2014, 09:58 AM
Pumpkin is a 70 1.7, Put on the new back brake disc, new pads, and figured out why back one hung up, piece of metal from old gear for setting vent clearance. got new one (gear) from Eric.
Question is, which order to do what, set vent clearance, bleed brakes, re check vent clearance?
Thanks
Cap'n Krusty
Sep 29 2014, 10:14 AM
Clamp the rotor to the hub with 2 or more lug bolts and spacers as necessary, set the venting clearance to .004", rechecking each side after the other is set. Bleed the brakes rt rear, left rear, right front, left front. Run a minimum of 8 oz. through each caliper.
The Cap'n
pilothyer
Sep 29 2014, 10:17 AM
Just like you said Set vent clearance, bleed entire system, recheck rear inner and outer clearances
hndyhrr
Sep 29 2014, 11:30 AM
Thanks guys.
URY914
Sep 29 2014, 11:54 AM
Repete at least twice to get all the air out.
Beeliner
Sep 29 2014, 08:06 PM
Just in time for my new master cylinder tomorrow. Thanks to all.
colingreene
Sep 29 2014, 10:48 PM
Set clearance to 4 thou?
i read 8. Could this explain why my pedal was not at the top?
i Think so.
