Cap'n Krusty
Feb 27 2006, 06:37 PM
QUOTE (Al Meredith @ Feb 27 2006, 04:34 PM) |
I was out at Chuck Beck house (he lives outside Atlanta now) last fall and the first thing I saw was a 4 cylinder 911 engine he built. I can't remember when he did it but I would say early 80's. I also have an old HOT VW's Mag from the "energy crisis" days where they built a 2 cylinder Ty1. I think there is an aero ty 1 engine that runs 2 cylinders on the same side. |
Ya coulda bought a REAL Porsche flat 8 yesterday at the Ustabedunkel's swap meet! The Cap'n
Mueller
Feb 27 2006, 06:40 PM
QUOTE (Cap'n Krusty @ Feb 27 2006, 05:37 PM) |
QUOTE (Al Meredith @ Feb 27 2006, 04:34 PM) | I was out at Chuck Beck house (he lives outside Atlanta now) last fall and the first thing I saw was a 4 cylinder 911 engine he built. I can't remember when he did it but I would say early 80's. I also have an old HOT VW's Mag from the "energy crisis" days where they built a 2 cylinder Ty1. I think there is an aero ty 1 engine that runs 2 cylinders on the same side. |
Ya coulda bought a REAL Porsche flat 8 yesterday at the Ustabedunkel's swap meet! The Cap'n |
what was the asking price?
is this part of the stolen Volask motor horde??
cbenitah
Feb 27 2006, 07:10 PM
QUOTE (Cloudbuster @ Jan 28 2005, 12:23 PM) |
Hans Dahlbeck? |
Ahh a swede, I should find out if its a relative.. imagine the typ of engine I will have when I'm done
Mueller
Feb 27 2006, 07:15 PM
QUOTE (cbenitah @ Feb 27 2006, 06:10 PM) |
QUOTE (Cloudbuster @ Jan 28 2005, 12:23 PM) | Hans Dahlbeck? |
Ahh a swede, I should find out if its a relative.. imagine the typ of engine I will have when I'm done |
I do less favors for relatives than I do for friends
you wouldn't get squat from me, hahahaha
I wonder if he ever moved over here to the US as the article states???
ClayPerrine
Feb 27 2006, 07:51 PM
How about something like this???
Mueller
Feb 27 2006, 07:52 PM
QUOTE (ClayPerrine @ Feb 27 2006, 06:51 PM) |
okay, spill the beans...whos 914 is getting that???
Aaron Cox
Feb 27 2006, 08:00 PM
i wanna say thats a photoshop.....
nice 907/908 motor
rick 918-S
Feb 27 2006, 08:01 PM
Dude! is that at your house?
Thant thing is awesome!
this whole subject to me is about the cool factor. I like the idea of tryin to build a a flat 8 from a bucket of parts and a tig welder. Who cares if it can even run. I would be cool to try.
bd1308
Feb 27 2006, 08:02 PM
i'll see if i can dig up two bus motors....
The VW guy owes me....
b
Brian Mifsud
Feb 27 2006, 08:22 PM
Mike...while your in there pouring aluminum, how about adding a few more pounds to the crucible.....
Do a straight 8 using the 911 heads arouind a chevy crank???
Brando
Feb 27 2006, 08:23 PM
QUOTE (Aaron Cox @ Feb 27 2006, 06:00 PM) |
nice 907/908 motor |
Ding ding ding! We have a winner! It is photochopped.
ClayPerrine
Feb 27 2006, 08:27 PM
FINALLY!!!
I was wondering when someone would pickup on the errors in my picture.
I actually would LOVE to do this. I have been thinking about it for a long time. I want to make molds of a 911 case, and make wax castings to cut apart to stretch. Then make molds for the stretched cases and cast them.
I would use a 3.6L case. If I were to do this, I would want to go BIG displacement!!!
Brian Mifsud
Feb 27 2006, 08:28 PM
Photoshopped??!! Well, if I were designing this thing in CAD, you'd do almost the equivalent in terms of "cutting and pasting" (well sort of)... this picture is excellent inspiration though for a very doable flat 8 using 911 parts and some off the shelf V8 stuff...
Mike.. think Propane, propane, Propane......
ClayPerrine
Feb 27 2006, 08:33 PM
The crank would have to be custom made. That would be the big expense. The cams and cam carriers could be made from existing 911 parts. Just cut and paste using a welder and a dial indicator for the cams. Setup each cylinder as if it were #1. Get the cams onto the proper lift with the crank at the correct degree setting and weld them together.
Make an extended oil pump drive shaft, and a flat fan. Use a distributor cap from a mercedes v-8.
It's doable, it would just take time, paitence, and money.
And it would be REALLY cool in a 914....... 4.8L air cooled flat 8.
ClayPerrine
Feb 27 2006, 08:36 PM
Mueller... you up for making a couple of custom cranks?
Thorshammer
Feb 27 2006, 08:42 PM
Well Actually no, never thought about doing a type four engine, However, my little devious mind has always wanted to do a three liter V8 using two Hyabusa (GSX1300 Suzuki) That have been over bored using a billet block and a custom crankcase and dry sump oiling system. Thought I would put it in a small formula car for hillclimbs. Used to get 260-280 out of 1480cc Bus motors back in the day, So I would say 475-480 on good gas would be the number. BTW, the reason you can't get double the hp is due to friction. More parts means more friction, there is a point of diminishing returns when it comes to adding cylinders. That it why many F1 cars stopped development on V12's. V10 WAS The best choice. now just freaking V 8's they suck.
The other idea I had was to use two FZR400 Yamaha Cylinders and heads and a custom made crank using the stock bore, but reducing the stroke so that I retained 640cc. This would give me a really nice bore to stroke ratio, and after some intake port epoxy and a scatter cam (one inlet valve opens before the other one to promote swirl) I think I could make 130-135 hp out of this one. Very cool. Counter rotating barrel valves, and injection with 4 valve cylinder heads. Very high tech, and very cool sounding. Would be a great FSAE engine. Little tiny gasps of air through that 20mm orifice. Yes, yes, yes, Oops I soiled myself.
Erik Madsen
Brian Mifsud
Hi Clay,
When you say a custom crank MUST be used, is that because the Porsche head and barrels are at too wide a pitch(i.e spacing of journals vs barrel width)??
Otherwise, just customize the parts AROUND the cheap crank.....
Intention would NOT be to be a 908 replica, but just a powerful lightweight flat 8 that can slip into the engine compartment without hacking it all up...
ClayPerrine
Feb 27 2006, 08:46 PM
QUOTE (Brian Mifsud @ Feb 27 2006, 08:42 PM) |
Hi Clay,
Otherwise, just customize the parts AROUND the cheap crank..... |
Nope. The porsche crank uses a separate rod journal for each cylinder. So we need to add 2 more rod journals and 2 more main journals.
I suppose you could cut up a BUNCH of 911 cranks and put together something that would work. But I would not try it with a custom made case.
And I don't know what firing order to use either.
This idea really gets me thinking... This would be SO cool with 4 dellorto/weber style throttle bodies and electronic fuel injection. Bet it would sound really nice too...
alpha434
Feb 27 2006, 08:51 PM
If you do a different firing order, then you'll have to do custom cams to match the new crank.
I would just offset one engine's crank 45 degrees. Exactly. Then no two cylinders are ever firing at once, and you could use a V8 ignition system, since all timing would be evenly spaced.
We're all lucky that flat engines are naturally counterbalanced.
Brian Mifsud
QUOTE (ClayPerrine @ Feb 27 2006, 06:46 PM) |
QUOTE (Brian Mifsud @ Feb 27 2006, 08:42 PM) | Hi Clay,
This idea really gets me thinking... This would be SO cool with 4 dellorto/weber style throttle bodies and electronic fuel injection. Bet it would sound really nice too... |
OKAY, so that IS because of the Pitch (or spacing) of the Porsche cylinder that THEY use individual journals.... That doesn't mean it MUST Be engineered that way from scratch. The OFFset of one bank to the other would dictate whether I needed to use individual journals.. since I could control the offset.. I COULD use the chevy crank...(and distributor, rods, flywheel... maybe more...)
eeyore
Feb 27 2006, 08:52 PM
QUOTE (Thorshammer @ Feb 27 2006, 06:42 PM) |
The other idea I had was to use two FZR400 Yamaha Cylinders and heads and a custom made crank using the stock bore, but reducing the stroke so that I retained 640cc. |
Just in case you didn't know, somebody is most of the way there
Drysdale
alpha434
Feb 27 2006, 08:53 PM
Can't use a chevy crank for a flat 8.
rick 918-S
ClayPerrine
Feb 27 2006, 08:54 PM
QUOTE (alpha434 @ Feb 27 2006, 08:51 PM) |
We're all lucky that flat engines are naturally counterbalanced. |
Won't work. It's not a type 4. It's a flat 6 that is getting stretched to a flat 8.
And I already covered how to get the cams correct.
Brett W
Feb 27 2006, 08:56 PM
The 180 degree 8 has a problem with second order imballance. It will shake at most street rpm levels. Most of you guys don't want to deal with that.
The 917 12s had problems with harmonics and crank vibration. This is why the fan and oil pump are mounted in the middle of the engine. You have to do this to keep those items alive.
You are better off just buying a Porsche flat eight. They aren't that expensive, when you look at what is involved in making your own.
Thorshammer
Feb 27 2006, 08:58 PM
One of the problems must be the design of a crank that does not extend the overall length of the engine by too much. This could be a major problem. It will probably have to use rods that are adjacent to each other liek a small block to keep the cylinder bore spacing decent.
As for the previous comment about bevel drive gear Carrera engines needing 40 hours to build. Yes that is true, if they are a new parts build up. However, if the time is taken upon disassembly to check tolerances and shims are kept in the proper order, then it is less than that. many Carrera Maestros (HA, HA, HA) keep the black art thing going to ensure no one else plays with them. Ensuring they have a place from now forth. But the main issue with 4 cam engines is parts availability or the ability to make some part that are NLA. This is the real issue. and thats why only two guys in the country do most of the 4 cam work. its either MT or CT, anything else is just a myth.
If you can work on a bevel drive Ducati, you can work on a carrera 4 cam.
BTW, why not make the V8 Type four monster use some Ducati Desmo air cooled cylinder heads. I have built many of those engines, the best we ever got in 750cc form was about 90-92 hp depending on the day. Which would mean 225 hp or so from 2.0 liters and 450 from 4.0 liters.
Just a thought.
Erik Madsen
alpha434
Feb 27 2006, 09:03 PM
Why we couldn't use a Chevy crank:
Counter balancing, and angle offsets for timing.
A 60 degree V8 with a firing order 1-2-3-4-5-6-7-8
and shaped like this
1----2
3----4
5----6
7----8
The crank is at 0deg for 1. The crank is machined so that the piston one is -30 deg off center. Two is 45-30=15. Three is 60. Four is 95.
ClayPerrine
Feb 27 2006, 09:06 PM
QUOTE (Brett W @ Feb 27 2006, 08:56 PM) |
The second order vibration issue was solved in the second generation crank for the 908 engine. At the Fort Worth parade I talked with a guy who does restorations on 908s about this. He sent me the 908 firing order,but I lost that email when I left MS.
Anything longer than an 8 in a 911 style engine would make the crank too long. That would produce the torsional losses that they found in the 917 engine that prompted the center drive setup on it. Even the output drive on a 917 is taken from the center.
I figure if this could be done, then it would require a flat fan. Any ideas on it?
alpha434
Feb 27 2006, 09:07 PM
QUOTE (alpha434 @ Feb 27 2006, 07:03 PM) |
1----2 3----4 5----6 7----8
The crank is at 0deg for 1. The crank is machined so that the piston one is -30 deg off center. Two is 45-30=15. Three is 60. Four is 95. |
Wait. I did that wrong.
You alternate add, subtract.
But the point is that with a flat crank, we're 180deg out. Not 60
lapuwali
Feb 27 2006, 09:18 PM
QUOTE (Cloudbuster @ Feb 27 2006, 06:52 PM) |
QUOTE (Thorshammer @ Feb 27 2006, 06:42 PM) | The other idea I had was to use two FZR400 Yamaha Cylinders and heads and a custom made crank using the stock bore, but reducing the stroke so that I retained 640cc. |
Drysdale |
Not most of the way, but all of the way. Ian Drysdale started with FZR400 top ends (barrels and heads) on a custom case and crank. He did this in the mid 1990s, and has been continuing development for years both of his engines and the custom chassis he builds for these engines.
The Radical engine is essentially the same idea.
The wackiest design I've seen was a "V8" made by simply gearing the output shafts of two complete ZX-9 engines together to a common output shaft (one through an idler), with the engines sitting "cheek to cheek". This made complete engine changes very easy, as long as you had a supply of used ZX-9 engines. It was very wide, but was built for a class of sportcar racing that required two side-by-side seats, anyway, so the width wasn't a problem. I believe a pair of ZX-12 engines were used by the same guy in a different car.
alpha434
Feb 27 2006, 09:22 PM
QUOTE (lapuwali @ Feb 27 2006, 07:18 PM) |
The wackiest design I've seen was a "V8" made by simply gearing the output shafts of two complete ZX-9 engines together to a common output shaft (one through an idler), with the engines sitting "cheek to cheek". This made complete engine changes very easy, as long as you had a supply of used ZX-9 engines. It was very wide, but was built for a class of sportcar racing that required two side-by-side seats, anyway, so the width wasn't a problem. I believe a pair of ZX-12 engines were used by the same guy in a different car. |
Like a W12?
Where do you guys find that stuff? These are Formula classes? All we have around here is SCCA.... F. Vee and Mazda star stuff.
Brett W
Feb 27 2006, 09:23 PM
Sorry I was referring to a 180 degree V8. Don't know much about the flat 8. I would guess it would be pretty close to balanced.
JmuRiz
Feb 28 2006, 09:31 AM
QUOTE (DuckRyder @ Jan 31 2005, 03:45 PM) |
QUOTE (jwalters @ Jan 31 2005, 04:47 PM) | Ala Ducati--if the Duc had four cylinders....... |
Trying to make a desmo valve system work without overhead cams would be ... probably impossible.
Once you've adjusted the valves on one, you won't ever try to convert something TO Desmo.
And there is a 4 cylinder Ducati, the DesmoDeci (vs DesmoDue) |
Well, there are a zillion styles of demodromic valvetrains. I came across this site a while back, TONS of info, movies and pics of different systems. You can have gear driven valves w/o OHC engine...it's just not as easy
r_towle
Jul 21 2012, 04:37 PM
It's time for this to finally happen
Parts heading to the machine shop with a goal of a spring firing
sixnotfour
Jul 21 2012, 05:26 PM
wow a Aircooled Pushrod Flat 8
seanery
Jul 21 2012, 05:45 PM
QUOTE(r_towle @ Jan 28 2005, 02:49 PM)
Has anyone tried to build a flat 8 with two type 4 motors?
Theoretical questions.
Assumptions
2 motors each producing 100 HP and 100 Lb/ft of Torque
The motors are end to end, front to rear.
The cranks are fastened together either bolted or welded.
1) Would you get 200hp and 200 lb/ft or torque? or is there some multiplier...seems like you would produce more torque..
2) could it be done with a single ignition system available for sale off the shelf.
3) could you do it without two distributors? crank fired ignition system..I am thinking that there could be a wheel placed in between the motors to give you something to time from.
4) I am assuming either a nice FI system, or four carbs.
Has anyone done this?
I would like to see some articles or web pages if this has been done in the aircooled world...
Thanx in advance
Rich
And I'm crazy for wanting to put a 928 in an old GMC?
r_towle
Jul 21 2012, 05:48 PM
Yes, you are.
At least it am staying in the family.
BigD9146gt
Jul 21 2012, 06:02 PM
Theres a guy down in Melbourne who has made flat 8's out of 6's, says they are really easy and has moulds for the 908 style fan shrouds... problem is my last boss has been trying to get parts off him for some years now. This is one of my all time projects I wish to make. Cudo's to you for trying it with the type 4 stuff... will be fun to fallow your progress.
rick 918-S
Jul 21 2012, 06:07 PM
Totally do-able with some planning. I'll be watc
hing this one!
Woody
Jul 21 2012, 07:43 PM
jwhcars
Jul 21 2012, 08:58 PM
The 2 factory 914/8 cars had 908 engines in them. The orange one had the full race MFI engine, and the grey one had carbs and was de-tuned for street duty.
There is one in the Porsche museum.
Dr Evil
Jul 21 2012, 09:11 PM
I will be doing this someday if no one else does...probably even if they do.
sixnotfour
Jul 21 2012, 09:17 PM
sixnotfour
Jul 21 2012, 09:33 PM
sixnotfour
Jul 21 2012, 09:48 PM
seanery
Jul 22 2012, 06:04 AM
QUOTE(jwhcars @ Jul 21 2012, 10:58 PM)
There are two in the Porsche museum
Mueller
Apr 13 2018, 07:43 PM
Back to the flat 8 talk....
Found out Ferrari uses flat-plane crankshafts in some of their V8's so I went on eBay and voila... I found this crank from a 328, 73mm stroke instead of the Porsche 908 66mm stroke.
Guy wanted $850 plus shipping, I offered about half that, he didn't quite tell be to F off, but I think he wanted to with his response, asked me to call if serious.
Anyway, while not as accurate as the 908 crank it seems like a cheap alternative.
Elliot Cannon
Apr 13 2018, 10:12 PM
There was a guy, Richard I think, who used to show up at the G&R all the time who planned to build an 8 cyl. type IV. Richard are you out there?
billh1963
Apr 14 2018, 04:41 AM
Isn't there a guy working on casting new 3.6 cases? Maybe he could cast one for an 8
DRPHIL914
Apr 14 2018, 05:47 PM
QUOTE(billh1963 @ Apr 14 2018, 06:41 AM)
i cant even begin to imagine what that would cost!
