OK - I found an exploded diagram that ThePaintedMan found for me last year when I was screwing around with my carb.
http://www.shoptalkforums.com/viewtopic.ph...64&t=139538(I'm always posting on here about my carb... still trying to figure it out but I sure am good at taking it off and putting it on now.)
So this part is called the accel pump weight. I can see that it is meant to impede the flow of the gas shot into the primary barrel from the accelerator. The gas is flowing straight up around the "weight" so gravity is holding it down. Maybe the reason is simply to stop gas from always flowing unless you're pressing the accelerator.
So again this is a half hollowed-out, hexagon cylinder. Just trying to figure out if the hollowed-out end goes towards the flow of gas or away from it. Trying to think of the thermodynamics of it and if it even makes a difference.
Yes I could just put it in and try it but I know someone on here just knows what it's for and why and how I should put it in. I would assume other carbs have a similar flow impedance mechanism?
Here is my post last year with other pics of may carb from all different angles. I know it's a weird one. Probably pulled off an opel in a junkyard or something.
more pics of my carb from another post
