Mmm that is a rather sexy set up !, on your 90's conversion bid they weld in part of the 911 firewall to give pedal clearance ?
I've been studying my firewall etc just need to have a good look at a 911 one now ! scrap yard here i come !
I found some pictures of a Crayford online but there not very clear.
Click to view attachmentClick to view attachmenthope they don't mind me using there pictures !!
QUOTE(edwin @ Oct 23 2014, 03:04 AM)
I have 1 that was converted in the 90's and is ok. Uses a rhd 911 pedal box and cut fuel tank. The dash is then sectioned and flipped
The one I'm currently building should look a little better when done. I'm using a tilton pedal cluster with double brake master cylinders and hydraulic clutch. The fuel tank I'll make from scratch and use an intank pump for the Fi I run. Also using a 911 steering column
Sorry about the pic being upside down. It's what we are used to in Australia and I'm on my phone
Admin edit: Rotateificated the image for 'ya ...
