Meyner
Oct 28 2014, 10:52 PM
Can anyone out there help me with a lighting issue. I got home with a beautiful 74 2.0 recently and it has issues with the running lights on the passenger side rear. I have brake lights on both sides working. Blinkers on both sides working but when you turn the head lights on only all lights work except for the all of the passenger sides rear?
Baffling me at this point. I have changed all light bulbs before running into this. Was missing passenger side brake light when I opened it up to check bulbs. All new at this point.
I will post some pix's soon of the beaut.
jcd914
Oct 28 2014, 11:29 PM
Do the right rear brake & turn signal lights work when the headlights are on?
There should be a gray wire with red stripes running from fuse 6 to the right rear tail light assembly.
Check to see if the wire is connected at each end.
Check for voltage at the wire when the lights are on.
Note: There should be another gray with red wire at fuse 6 that goes to the right front running lights.
There are wire diagrams available on the Pelican parts website.
Good luck
Jim
etcmss
Oct 29 2014, 03:06 AM
check tail light wiring to Jeff's drawing....
http://bowlsby.net/914/Classic/zTN_Elect_Tailights.jpgwere all the lights working before you changed the bulbs?
Gary
