Full Version: Headlight motor wont turn off
What would cause one headlight to cycle up and down until I pull the relay. Just started today.
Dave_Darling
Sticking relay, or bad microswitch in the motor housing.
Swap the relay with the one from the other light. If the behavior follows the relay, you've found your culprit.
--DD
7TPorsh
Check yer grounds....brown wires
7TPorsh
Relay. Thanks guys!
sfrenck
QUOTE(mepstein @ Oct 29 2014, 12:35 PM) *
Installation of a new / fancy set of LED lamps...
QUOTE(sfrenck @ Oct 29 2014, 02:09 PM) *
sfrenck
QUOTE(mepstein @ Oct 29 2014, 02:29 PM) *
Tom
I believe a shorted diode will produce that same symptom.
Tom
I switched in a new-old relay and it's been working right.
