I'v got a 74 2.7 with the stock flywheel (and the KEP adaptor) which pilot bearing will work when mating it to the side shift box i have?
Will 901-102-025-01-M157 work as it it the bearing from the 74 engine? or do i need to get one from type 4 engines?
Just curious if the input shaft will fit the diameter of the 911 engines bearing.
