Peashooter
Oct 30 2014, 01:46 PM
I was wondering if any of you serious autocrossers have considered changing out the R&P? It seems like it would make a huge difference in how the car accelerates out of the tight bits.
The PO of my car was going to build it as an autox car, and bought a brand new Porsche ring and pinion set, in 6/29 ratio. I don't need it and was thinking someone may be interested?
Bill
crresind
Dec 4 2014, 07:33 AM
There is really no good use for this ring and pinion setup. The ratio works out to 4.833:1 vs stock 4.428:1. This is an even lower, meaning stump-puller, ratio. It might be useful for a hill climb/rock crawler. The REAL reason that it is not practical for long term use is the fewer pinion teeth. It tends to wear out much more quickly.
ChrisFoley
Dec 4 2014, 09:56 AM
It has value in SCCA Improved Touring where gear changes are not allowed but R&P changes are allowed.
The stock gears are too tall for racing, even with a low rpm engine like stock.
The short R&P gives a roughly 10% rpm increase at any given speed.
