Now it's on the way to me.
1973 signal orange. 1 owner the last 29 years. Original radio..everything works except cigarette lighter and washer squiters.
This was the non original engine that I posted a question about "value". It was upgraded to a 1911 back in 01.
Dual 34ICT Weber carbs - 1911cc w/96mm pistons & liners - hydraulic lifters, (no valve clearance adjusting) - street performance cam - hardened valve seats - high volume oil pump - auxiliary oil cooler w/fan -Pertronix breakerless ignition, (never change points again) - 911 turbo tie rods - Bilstein struts & shocks - Bursch muffler - hybrid hi-torque starter - rebuilt front calipers - German rebuilt ATE rear calipers - parking brake works - virtually all rubber has been replaced - carpet replaced - vinyl on seats & back panel as well as fuzzy strip in windows replaced - original radio still works - flawless dash. Turn signal/dimmer & wiper/washer mechanisms have been replaced - factory Pedrini alloys w/correct center caps.
I will probably engage the good Dr. to refresh the 901; 1st and 2nd are sensitive on downshifting. All shifter bushings have been replaced.
I will update the VIN Registry
All southern car it's entire life, so very dry (I know, I know
Everyone always asks for pictures, so here is what I have so far.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=473
704]Click to view attachmentClick to view attachmentClick to view attachment[attachmentid
=473710]Click to view attachmentClick to view attachmentClick to view attachment[attachme
ntid=473714]Click to view attachmentClick to view attachmentClick to view attachment[atta
chmentid=473718]Click to view attachmentClick to view attachmentClick to view attachment[
attachmentid=473722]Click to view attachmentClick to view attachment[attachmentid=4737
25]
