r_towle
Nov 4 2014, 07:45 AM
When prepping a car for sandblasting, what is the common thing to do with the aluminum tags in the front trunk and door pillar?
I suppose the second question would be do I acid dip the car or get it sandblasted?
cn2800
Nov 4 2014, 07:59 AM
I very carefully drilled out the rivets for those tags (don't forget the Karmann tag on the driver's door hinge pillar) and will rivet them back in place once paint is complete.
I've contemplated dipping the body, but have ruled it out since there's no way to remove the hot air tubes from inside the longitudinals without major surgery. I've read here that they're foil-lined cardboard. I can't imagine they'd fare well in an acid bath.
r_towle
Nov 4 2014, 08:11 AM
QUOTE(cn2800 @ Nov 4 2014, 08:59 AM)
Look for threads here, McMark just cut open the longs from the outside in that area and removed the heater tube.
Give you a nice way to get access to spray in an epoxy coating after the dip is completed, then put the tube back in and close it up.
I am torn about which way to go with stripping....not sure if I want to deal with the level of work to get paint back on all the nooks and crannies that an acid bath would remove.
Also, not sure I don't want to do that....cause it's a good thing to do once and do right.
Nov 4 2014, 08:24 AM
I wouldn't acid dip. You'll never be able to protect the spot welded seams.
rudedude
Nov 4 2014, 08:32 AM
Seeing the damage done to a 356 from dapo that I am restoring I would never have a car acid dipped.
r_towle
Nov 4 2014, 08:33 AM
QUOTE(mepstein @ Nov 4 2014, 09:24 AM)
After 40 years, they are no longer protected anyways.
stevegm
Nov 4 2014, 08:36 AM
I researched this pretty well a while back, and spoke with a company in Charlotte that does the dipping. Unless the car if very rusted, they didn't think dipping was the way to go. My conclusion was that dipping was too risky and media blasting was a better solution. Just my .02 cents.
altitude411
Nov 4 2014, 08:40 AM
Plastic bead media blasting is the way to go in my opinion. Very gentle on the metal (doesn't pit or stress) and more control over the amount of material removed. You can leave the seam sealer intact and the media is easily removed with air. Can be used on fiberglass without removing gel coat. This is what is used on aircraft aluminum.
rgalla9146
Nov 4 2014, 03:19 PM
QUOTE(r_towle @ Nov 4 2014, 08:45 AM)
Carefully drill the two pop rivets under the front hood.
The paint/body tag on the drivers door pillar can be removed by pushing the rivets out with a lever arranged through the speaker recess.
Push them out slowly, each one a little at a time.
The rivets can even be re-used, or.... Stoddard sells them.
I'd blast it.
But tape and plug every opening or you'll have a pile of sand fall out every time you close a door.
rick 918-S
Nov 4 2014, 04:10 PM
http://www.914world.com/bbs2/index.php?sho...=230343&hl=I would cut the longs open and do this. The only welding you would do is replacing the outer, sill and triangles. You could use eastwood encapsolator to protect the inside of the weld area.
balljoint
Nov 4 2014, 04:29 PM
I get sand all over the dash every time I turn the fan on to defrost the windshield.
SixerJ
Nov 5 2014, 05:05 PM
Maybe useful background info, but unfortunately doesn't not resolve your personal dilemma
Acid dipping is big business in the UK and there are two well established companies with slightly different processes
http://www.surfaceprocessing.co.uk/for-cars.htmlhttp://www.envirostripukltd.com/portfolio/auto-restorationSPL have been going for years and years and have slowly improved the process and added steps, the final part being a modern ecoat which should help resolve the enclosed and hard to get to spaces which would be key for me personally. They have some potentially interesting info as to how to improve the dipping process - drilling small drain holes etc
Envirostip use an a kind of autoclave idea in the 1st instance to break paint, sealant etc down, then a much more expensive acid process to kill the rust (in comparison to SPL) which results in fewer issues later
I like the idea of Envirostip but not the fact you are left with an unprotected shell in cavities. They do etch prime, but that does not resolve the cavity issues
The blast verses dip camps are fairly polarised here
The results of long term dipping I should be able to post once I start work on my -6 as I spoke to the PO yesterday and he confirms it was dipped in the early 2000's. The closed compartments worry me as this was before the days of ecoat and protection will only be as good as getting the cavity gun in there. As she's was a race car I guess the heater tube issue did not matter
If you do decide to dip you must remove the alloy tags as apparently the acid will eat them for lunch
r_towle
Nov 5 2014, 05:37 PM
Interesting note, the initial dip is a BASE.
The acid dip, typically phosphoric acid, is down to neutralize the base and stop the process from continuing.
Phosphoric acid also helps stop rust from continuing...same reason.
Then wash it off with water...
So the car sits for a long time in a base solution, and is dipped pretty fast into an acid bath.
Now I want to go out and weigh a small piece of sheet metal and put it into phosphoric acid for a week to see what happens.
Rich
lsintampa
Nov 5 2014, 06:00 PM
I acid dipped....
Then por-15 the entire car...
Had to dip it twice - the first round we didn't get it cleaned in time and it started to rust again...
I've no experience with media blasting.
Acid takes it down to it's roots - that's for sure.
Sorry I don't have photos handy of the after-bath... but here's how it came out in the end.
Ended up selling it to a classic car dealer - his pro photos towards the end....
https://plus.google.com/photos/116912054149...CLGryuPK67yhzwE
Mikey914
Nov 5 2014, 11:32 PM
I've used soda blasting to spot clean a few areas.
Nov 6 2014, 11:09 AM
lsintampa
Nov 6 2014, 11:32 AM
Sand will get into everything, for sure. Ever go to the beach?
Anyway, the question sort of implies dealing with only the metal - as in the body and associated parts are void of all other parts, etc.
I've heard of shops that will media blast a "roller"...... IDK, IMHO when you get to the point of asking acid or media / I'd assume it's just body metal.
If the care is that far down to just body parts, it's just a matter of choice. Either process requires a lot of cleaning up afterward.
r_towle
Nov 6 2014, 06:30 PM
My plan, either way, is to strip it to the tub and bring it to a place on a dolly.
So it would just be a bare tub, which
I am not looking forward to....just cause it will create thousands of little projects...
Rich
Katmanken
Nov 6 2014, 06:31 PM
And you can do the electrolysis process on a whole car too. Place in Cincinnati called American Metal Refinishing that used that process to clean some fenders and a rear lid on my teener. Parts went in rusty and painted, and came back beautifully cleaned. They even knocked the rust out of the fold at the back of the rear lid. Parts were charged and lasted for more than 6 months without rusting. Watched them haul an old model T out of their inground pool and an engine block. Looked great. Looks like they are a chain with a few more places here and there.
Doesn't go between welded seams, but then nothing does.
r_towle
Nov 6 2014, 06:35 PM
I am starting to lean toward dipping the car, then sending it to a shop in Boston that Cevan found and have the whole thing galvanized.
I would not galvanize the removable panels, and depending upon what I find out, I may just sand off the top of the tub in prep for paint.....but then the underside and all the little nooks and crannies could be galvanized...
No idea what it might cost, but it won't hurt to investigate this.
Rich
roblav1
Nov 7 2014, 12:59 AM
I just went through this. Aircraft stripper - let it sit for an hour - then hit it with a power washer. 4 gallons did the entire car (approx $40 per gallon) - inside and out. It IS A PAIN!
Phoenix-MN
Nov 7 2014, 07:26 AM
QUOTE(Katmanken @ Nov 6 2014, 04:31 PM)
This is how I did my chassis, years ago there was a shop in White Bear Lake that did this process. The chassis didn't flash rust at all and I worked on it for a whole summer before sealing it.
CptTripps
Nov 7 2014, 09:01 AM
QUOTE(rick 918-S @ Nov 4 2014, 05:10 PM)
+1 for
http://www.redi-coat.com/If I had to do it over again, this is what I'd do. For $2,700....that's well worth it in my opinion. Here's what I spent to get the car that far.
Media Blasting: $1,000
Epoxy Paint: $300
Stuff to coat inside of longs: $200
So I'm $1,500 into mine, and there is still likely surface rust hiding in nooks and crannies inside the longs and such.
RediCoat makes sure you have a 914 that is quite literally "rust free".
boxsterfan
Nov 7 2014, 04:33 PM
Take the floors out. There is rust in the seams. And if I'm doing a car, I'm cutting open the longs to get every inch I can in there.
SixerJ
Nov 8 2014, 03:25 AM
QUOTE(CptTripps @ Nov 7 2014, 03:01 PM)
+1 for
Epoxy Paint: $300
Quite possibly a stupid suggestion - why not cut open the longs, replace the heater tubes with steel tube / fixed with a silt down the tube & jubilee clips (like some exhausts). Then send it for its final bath and ecoating?
You now have a 914 that does not have to be messed about with post dipping
Also question for Rick / Scotty / pro body guys. Is there any special prep that has to be done to ecoat before paint? I have heard that primer does not adhere well to ecoat and you have to rub it all the way or a fair way down, that does not make sense to me as every automotive manufacture now uses ecoat and they are not going to do this. I could see you would have to key it up with scotch brite / DA etc but rubbing right down kind of defeats the whole idea of the protection - sorry for the hijack
Jon H.
Nov 8 2014, 08:45 AM
If you spray you high build primer on top of the epoxy within 48 hours you not need to sand the epoxy coat. Unless the epoxy coat is baked. This for Nason brand products. I'm sure other brands are similar.
Jon h.
partwerks
Nov 8 2014, 07:29 PM
QUOTE(r_towle @ Nov 4 2014, 06:11 AM)
Where exactly would need to be cut open to remove the heater tubes to address any possible rust issues?
veekry9
Nov 8 2014, 08:13 PM
Redi-Strip.
http://www.redi-strip.com/https://www.facebook.com/pages/Redi-Strip-C...128612050544459Many decades in the biz.
Phosphate post coating for rust inhibition.
A rare rusted 4130 airframe?
Yup.
http://www.nemgtr.org/index.php/members-ho...strip-revisitedhttp://www.jalopyjournal.com/forum/threads...p-in-pa.127217/http://www.redistripindy.com/The marketers of Vise-Grip also carries Cling-Surface,a prepared bath for rusted parts.
Cleans heavily varnished ferrous internal parts perfectly.
veekry9
Nov 8 2014, 08:24 PM
Come to think of it,I haven't come across anyone here on the World who has demonstrated the naval jelly method of rust removal.
I used it recently to treat the seams of the hood where a line of corrosion peeped through the original paint.
A few gallons of the stuff works wonders on a very thorough level.
Maltese Falcon
Nov 8 2014, 09:57 PM
Had our current- build blasted with garnet sand. The media blast co. said that the 914 has the softest metal of all Porsches.
The grit + psi needs to be just right to avoid blasting damage.
Yes we are pulling sand out with vacuum cleaners + blowing it out too...but the unibody looks brand new, and welds like a dream !
Marty
McMark
Nov 9 2014, 10:47 AM
QUOTE(SixerJ @ Nov 8 2014, 01:25 AM)
I think I would go this route if I were to dip another car.
Check out
this thread to see what you're heading for.
r_towle
May 15 2017, 10:27 PM
So, a few years have passed. What does everyone think about dipping versus media blasting?
My new plan is to send it out for blasting, metal work, then paint.
I don't have the time or energy anymore so I need to hire this work out.
I am going to strip the car, put in door braces....dolly or rotisserie depending upon how I choose to clean it. I am leaning towards media blasting it so I can leave the longs alone.
Wow, three of my go to mentors are gone
I need to get this car done.
r_towle
May 15 2017, 10:35 PM
Best/sad part of this is I was searching for any threads on this topic and I found my own thread, and I could not remember I ever asked this......ahhh
McMark
May 16 2017, 06:38 AM
Blasting for me.
bulitt
May 16 2017, 06:58 AM
QUOTE(r_towle @ May 16 2017, 12:27 AM)
Just use your abrasive personality?
IronHillRestorations
May 16 2017, 10:16 AM
If you have a really rusty shell, then dip it, but there's a lot of work in that.
If it's a solid car and you just want to have the exterior paint removed, then see if you can find someone who does soda blasting.
DIY chemical stripping is OK too but messy. I tape off all the seams so the stripper doesn't get in the jambs, etc. A few tips I've picked up on the aircraft stripper are: apply it with a single brush stroke and don't brush over it; once you get like a 1' x2" area coated, cover it with plastic film, this slows evaporation and forces the solvents into the surface. Cover the floors, wear gloves, eye and respiratory protection in a well ventilated area.
rgalla9146
May 16 2017, 12:43 PM
QUOTE(Perry Kiehl @ May 16 2017, 12:16 PM)
Yes, yes,yes,yes and yes.
Also, do it on the hottest, sunniest day possible, outside.
6freak
May 16 2017, 02:20 PM
QUOTE(McMark @ May 16 2017, 05:38 AM)
Blasting for me.
with ice! look into that, it works good and no sand or HAZMAT to deal with
amfab
May 16 2017, 03:01 PM
QUOTE(roblav1 @ Nov 6 2014, 11:59 PM)
Click to view attachmentI am curious about the reinforcement you did that ties the rear of the inner longs to the inner firewall. do you have a closeup of that?
Thanks
-Andrew
jimkelly
May 16 2017, 06:24 PM
the question i have about acid dip is that all paint will be removed but there is no way a normal paint job will get to all places an acid dip will leave bare. seems to me sand blast is bets option?
bulitt
May 17 2017, 07:40 AM
Rich: talk to Scotty. He has the dustless set up and mixes in a zinc solution to help with flash rust. Wonder what % of the abrasive gets washed away out of the nooks and crannies? But he could tell you.
May 17 2017, 07:57 AM
QUOTE(bulitt @ May 17 2017, 09:40 AM)
Unfortunately, the dustless setup isnt all its cracked up to be.
r_towle
May 17 2017, 08:07 AM
I am not doing this project, I will sub contract it out.
That said, Scotty currently has a very long lead time.
I will need to get it stripped before I send it somewhere for the metal work to be completed, so my feelings today are media blasting and let Abel (my son) deal with the rust that happens down the road from the inside of cavities...
Rich
cary
May 17 2017, 08:20 AM
On Doug's project we went with soda blasting, rinsed with Hold Tight then sprayed with SPI epoxy primer. All of this was done on my rotisserie so it was real thorough. I dropped it off at the soda blasting shop and picked it up at the paint booth.
http://leonardsodablasting.com/?gclid=CjwK...iDJPRoC2uvw_wcBhttp://www.holdtight.com/You have to confirm with Doug, but I think it was right around $3k for everything.
roblav1
Sep 2 2017, 06:21 PM
My old car is the white one in the rotisserie. I built it for a 993 engine. Unfortunately, I sold it in early 2015.
Someone asked about the diagonal sheet steel I welded into the rear corners. I stole the idea from early 911 Targas, where Porsche did something very similar. IMHO, after studying the chassis structure, I believe it will help quite a bit. I made them about 5-6" wide at the diagonal and bent at the top and bottom to get a good weld in shear. I was concerned with the seat not going all the way back, or I would have made them wider.
Anyway, I'm looking to do another 914 into a six. So if a decent chassis comes along, I'd be interested.
Thanks,
Rob
Sep 2 2017, 07:44 PM
I've been thinking about this. the 911 chassis that we get media blasted come out ok but our metal guy still has to do a ton of work once we get them back. Cut out all the swiss cheese metal that was hidden with paint and bondo, remove a lot of the epoxy primer to do the metal work, ect.
Recently we sent out some tubs to an acid dipping co. and I'm waiting to see the results.
I know the paper heater tubes dissolve in the acid.
Here's my question. what if I replace those tubes with another one by snaking it through the openings on each end of the long. Similar to what is done with oil lines on a 6 conversion or water lines on a Suby. I know the lines will have a smaller ID than stock but they could be thin walled (no high pressure like an oil or water line) so maybe the ID is big enough. If I can get enough hot air through the tube, I wonder if a large, insulated tube is needed. Even the heat on my 4 cylinder car, without a working electric fan, is HOT in the winter and unlike my daily driver, I'm not driving my six on the coldest days of the year. I'm really just looking to stay warm on the >40 degree days.
CptTripps
Mar 23 2021, 09:37 AM
::: digging up an old topic, so I don't have to make a new one with the same question :::
Is the general consensus still that media blasting is the better option to dipping? Just checking to see if there's been a technology advancement or more opinions.
I called a few dipping places within a few hours of me, and got quotes from $3,000-$4,000 to dip a chassis.
Found a local place that media blasts, and got quoted under $500 for the tub if it's on a rotisserie.
Leaning towards blasting again, but looking for if someone found a better way to go about it.
ClayPerrine
Mar 23 2021, 09:47 AM
QUOTE(CptTripps @ Mar 23 2021, 10:37 AM)
dipping will dissolve the paper tubes in the longs....
Media blasting will not.
And it is cheaper.
Clay
Root_Werks
Mar 23 2021, 10:02 AM
If you want to dip, prepare the body for it. I've only dipped two cars, both 356's and it's a DEAL to have done. Getting almost impossible to find a shop with a tub large enough and spend the time on a car body anymore. No money in it for them.
Bare body delivered and I mean bare
Little holes drilled to ensure air bubbles can escape
Dipped, wiggled around, turned over a few times (super cool to watch, friggen stinks though)
Then the hard part comes, gotta get all the acid off and out. I forget what solution is used, but they basically pressure wash the body for 3-4 hours. Tilt it, giggle it, wait, blast with air, pressure wash again etc. This is the longest part.
Then dip it in a phosphate solution = never rust again!
Had it done in Canada back in 2018 and it was roughly $12k US back then. Don't think the shop does car bodies anymore.
Mar 23 2021, 10:07 AM
Plastic media blasting worked well for us when I worked at the shop.
There is no best method, just what’s best for you. They all have comprises.
We used a place called - plastic media blast, near philly pa.
