QUOTE(Cap'n Krusty @ Nov 7 2014, 01:55 PM)
If you have a 1.7 case, it would be good to check the case and be sure it's one that has provisions for mounting the windage tray. Many early cases lack the channel for the seals.
The Cap'n
, and of course who wouldn't
Your early 1.7 case needs to be at least engine# W0 074 387...from this case on will have the required shelf for the baffle plate to rest in..........also be sure to use the seals on the baffle plate or you will have a rattle you don't want in there.
