QUOTE(rgalla9146 @ Nov 7 2014, 09:07 PM)
QUOTE(HalfMoon @ Nov 7 2014, 09:33 PM)
I wonder what performance we could expect over 911 calipers...
The 911 and 914 6 vented rotors are 19mm so 24 mm seems more likely than 20 mm for the 928.
OK, you can mount the caliper.
What 24 mm rotors is adaptable ? front ? rear ?
I'm asking because I'm doing a conversion 6 GT and can get the 928 calipers from a local wreck.
Will a 23 mm master be compatible ?
I guess 911 hand brake parts are part of the deal too
Hi Rory,
How is my old car coming along? Post a few pics of it.
Are you looking to put the calipers on the front or rear of the 914?
I was looking at doing the S4 caliper f/r swap on my 6 but went with a Boxster
f/r setup instead. It was an easy bolt on setup once I had all the parts on hand.
I don't recall if I showed you that Boxster setup when you where here last?
My old 71 914 had a setup like the one you are looking at. I used the 928 S4 rear calipers (which take the same pads size as the 930 calipers) with 84-89 911 Carrera 24 mm front rotors with standard 911 hubs. On the rear I used the 911 sc calipers/rotors. The S4 calipers mounting holes had to be machined a little like Bruce stated. You need to make sure the larger sized piston is on top so you may need to swap the lines around too.
I was taking a machine shop class at the time so I asked my instructor if I could do it on one of the presses.. It was fairly easy to do just have the struts with the hub/rotor mounted and handy to make sure things line up properly.
I used a Mercedes 23 mm master as well. I had to make the push rod longer to fit the master or you could replace it with the longer 911 type. The brakes worked great minus the rear e-brake. I drove the car with this setup for several years on the road and track. I never had a problem with the setup that is until I stopped too quick once but the car behind me didn't. I liked the brake setup and it all fits under 15 '' wheels.
I'll hit you up the next time I'm in your area.
