jim_hoyland
Nov 12 2014, 05:53 PM
Did some testing today and found the VDO voltmeter ( half gauge style like the 911 gauge )reads 1.5 low.
Can the needle be adjusted ?
914Sixer
Nov 12 2014, 07:14 PM
Probably have to go for calibration to one of the shops
bdstone914
Nov 12 2014, 09:33 PM
I would pull the gauge and test it with short leads to battery to make sure it is not a problem with any of the wiring. Then testcthe vattery with a good multimeter.
Is it reading too high or too low?
If too high you might be able to put a resistor inline to drop the reading.
jim_hoyland
Nov 12 2014, 09:55 PM
It reads about 1.5 v low. I,lol try your suggestion
Mike Bellis
Nov 12 2014, 10:05 PM
You could easily be dropping 1.5V through the wiring and chassis ground since these are 40 years old and full of corrosion.
v82go
Nov 13 2014, 06:51 AM
Not sure about yours, but the 914 volt meters that came in the factory console do
have a internal adjustable pot to calibrate them. You can access this by removing the
case.
76-914
Nov 13 2014, 09:53 AM
Mike makes a good point. When I built "Kugel" I ran a dedicated line for the voltmeter to rid it of lies. Glad I did that!
jim_hoyland
Nov 13 2014, 02:52 PM
QUOTE(76-914 @ Nov 13 2014, 07:53 AM)
That did the trick ! Ran a wire from the gauge to the battery, reads perfect. I wired a relay right behind the gauge so the Voltmeter won't remain on when the ignition is off.
Thank'so for the suggestions...
McMark
Nov 13 2014, 04:37 PM
And now you won't get a 'voltage drop' when the lights, heater fan, and blinkers are on.
76-914
Nov 13 2014, 04:46 PM
QUOTE(McMark @ Nov 13 2014, 02:37 PM)
Every newbie will ask that question sooner or later. I did.
Or the question re: one side of the car's parking lites staying on??? I feel like saying, "Here's your (newbie) Sign!
larryM
Nov 13 2014, 08:24 PM
X@
QUOTE(Mike Bellis @ Nov 12 2014, 08:05 PM)
just make a mental note of the difference and live with it
Spoke
Nov 14 2014, 06:47 AM
QUOTE(jim_hoyland @ Nov 13 2014, 03:52 PM)
Did you include a fuse in line with the battery? If not the wire will become the fuse.
jim_hoyland
Nov 14 2014, 08:30 AM
QUOTE(Spoke @ Nov 14 2014, 04:47 AM)
Will do ! Thanks.
siverson
Nov 14 2014, 06:20 PM
QUOTE(McMark @ Nov 13 2014, 03:37 PM)
i like those quirks
worn
Nov 14 2014, 06:53 PM
QUOTE(jim_hoyland @ Nov 12 2014, 07:55 PM)
The new ones have an adjustment screw on the side at the threads for the attachment ring. Glad you fixed yours.
