QUOTE(tach @ Nov 16 2014, 12:50 AM)
It seem the ones I have are .003 to small on the outside diameter to fit correctly in the case bore. Has anyone ever put brass shim stock strip with pump oil port holes cut out and installed the shim around the pump when the engine is being assembled. Skip the o-ring method.
Pump tolerances have sucked long time sailor.
Return it and try another pump.
I O-ring and install before I tighten the case halves.
I would never use shims like that....you may as well fill your oil galleys with RTV and get your engine failure over with.
