I am finally up against a wall. My life has changed enouph in the last 4 years, I have to part with my 914 and 20 years of parts.
Problem is... I am short on time. and need it all gone at one time.
The car is complete but a little worse for all the storage time. It was parked after getting broken into. I will get pictures of it (if I can clear enough junk from around it). Has rebuilt fully working fuel injection but apart for air leaks in the connector hoses. has 5 lug conversion stock brakes in the back and modified front hubs running 911 brakes (have vented rear rotors and spacers for calipers but never installed)
parts I have:
complete 2.0 motor in parts.
1.8 liter case
1 trans-axle case with internals from 2 trans-axles as parts
2.0 center consul
oem rear window with defrost
3.5 liter rover block and heads
1.8 liter heads
demello machine crankshaft 76mm stroke(?) with honda/ toyota bearing size (1.889 5 journals)
3 lightened flywheels (needing regrinding)
extra seats and door handle parts
much more as I can find it
and the biggest thing I have... no clue what its all worth any more. I have been out of doing anything with these for so long, and because of my time crunch. Please make offers
