QUOTE(BIGKAT_83 @ Nov 16 2014, 05:02 PM)
QUOTE(partwerks @ Nov 16 2014, 07:13 PM)
I think that just tells me on the first step what I already have done?
Maybe it can't be reskined? Built in obsolescence.
You better read it again. If you got to the part that says be careful and don't hit yourself in the face you have gone too far.
Begin by unclipping the shifter boot from the rear and lift it up (inset). To remove the shifter knob some cars use a set screw, and some require you to twist the lower collar 90° and then lift to remove. Remove your old knob by simply pulling upwards on it: be careful not to accidentally smack yourself in the face!
Any info above this part is telling me about the short shift kit.
I already have the shifter knob off.
What I was trying to find out, is if there is a way to effectively remove the leather from the shift knob itself?
