Rear hubs with short stubs sold.
I have the following for sale:
One pair of late 914 rear hubs converted to 5 lug with Veribus studs $200.
One pair of early front rotors with 65mm press in studs. They only measure about .007 under new thickness. Note these are early and only work with non hub centric wheels and early front calipers. $125.
One new 914-6 rear rotor. No markings as to the manufacturer. New ones are about $90 asking $60. A 914-6 rotor is 4mm larger diameter and needs to be turned down to work on stock 914 rear calipers. Also the 2 screw holes for the -6 rotor that attach it to the hub are in a different location than the 914 ones so you either have to redrill holes in the rotor or drill and tap 2 new holes in the hub.
One rear pair of 914 hubs with 65mm studs. Used and dirty but in good condition. Studs are threaded most of the lenght. Usually 65 mm studs require a 21mm spacer.
I have one set of shorter studs that I can swap into them or supply them without studs.
$150 with studs $125 without studs.
