QUOTE(stugray @ Nov 17 2014, 09:46 PM)
I plan on closing off my front side marker light holes before body work & paint.
I have only very minor work elsewhere, so the signal hole closeout will be the hardest of all the body work.
I can weld & have tig, mig, and even oxy-acetylene if I got some bottles.
What welding techniques worked for those that did it?
Full weld, tack weld only, seam weld, braze, filler, no-filler, copper backing plate?
Any experiences out there?
Both sides look like swiss cheese because the PO took off the lights and pop riveted covers over the holes drilling ~6 extra holes in the process.
I am worried that too much heat will warp the fenders which are otherwise perfect.
I hear that dollying/peening the area gently right after welding relieves stress, but isnt that also how you enlarge steel to "stretch it" too?
Doesnt Heat & dolly = bigger?
How the worm turns. The introduction of side markers by federal mandate drastically reduced what are commonly called t-bone crashes at night. In your case without the markers, you would be at the top part of the T. I personally, using my own flawed risk calculator, feel this is dangerous. Backed by those statistics and a bit short of 50 years driving for experience chops, without an accident. If the car is for shows, all bets are off. If you think it will only be out during the day that helps, but is no guarantee. And as mentioned before any modification of such safety devices would potentially put you in the wrong in court.
I hope we are still buds.
Ok. First cut a patch for the big hole and gently butt weld it in. You may need to do a tiny amount of hammer and dolly work after you grind down the weld. In general, if the hammer doesn't ring against the dolly you are shrinking and if it makes a clear ringing contact the metal is stretching, but that is awful general. For the little holes I would simply close them with little buzzes from the mig without reducing amps so you get good melting. You know it's too hot if the hole gets larger instead of smaller. Copper backing helps but also changes penetration. Actually, I doubt it will be a problem, although am sorry about the extra holes. Then you can lead or bondo. I recently started lead work on a 911, but it is much harder on a vertical and frankly I doubt it is better. Use your hand instead of your eyes for body work. You feel flaws that are invisible. I hope this works out. I do think you are safer with the markers, but really it's your call. Onward amigo!
