So here is how I did this. Used warped pedal board to make pattern in 3/4 plywood. Clamp aluminum honeycomb to pattern and use ball bearing pilot bit to make the pedal board. I find that the stuff is incredibly strong - I couldn't bend a 4 inch wide panel with all my strength pressed against it. So for $50 shipped I got 3 pedal boards and then got tired of making them so I will use the leftover later. The last one I timed - 20 minutes including clamping and pilot hole drilling. Of course you get covered with aluminum chips because it is a screaming router. But no worse, probably easier than doing woodwork. Safety gear.
Here are the results. I will epoxy small aluminum plates where bolts attach etc.
So has anyone done this? I used 1/4 inch thick with 1/4" cells.
