I started a previous thread questioning the need to spend $3.95 each for engine mounting bolts (1973 year) when they should be much less at a local hardware store.
Common reasoning was stick with the genuine part to make sure the bolts conform to specs, unless I actually know what I am buying. Not knowing much about bolt grade markings then I went with the $3.95 parts. Well, turns out they are nothing more than metric class 8.8 common bolts.
How much do these cost at your hardware store? Is there a premium for the black coloring? Or, am I still missing something? I mean the marking on the bolt head should tell it all: medium carbon steel, quenched and tempered, load=85K psi, yield strength=92K psi, tensile strength=120K psi. Even James delivers his motor mounts with class 10.9 bolts.
-Jeff
