QUOTE(roblav1 @ Nov 19 2014, 07:51 AM)
Either weak 1st synchro, clutch release bearing, or maladjusted clutch pedal movement. It could also be the oil used in the box. In my experience with the 901 box, the 1st synchro tends to be weak, and I would usually put the car in 1st while still slightly moving and leave the clutch in while at a stoplight / sign.
OK thanks. I replaced the clutch release bearing when I rebuilt the engine. Could be the clutch pedal adjustment though. Will check that out.
