DavidSweden
Nov 20 2014, 05:21 AM
Is a special puller required to remove the hub adapter from the crank?
How do you do it
Thanks
pilothyer
Nov 20 2014, 06:34 AM
After removing the center bolt I have never had to do much more that tap a little to get it off, but if it is really fussy there is a special tool. You can look at this and come up with your own idea:
914Sixer
Nov 20 2014, 06:45 AM
Just put some thick flat washers behind each bolt and alternate tightening them. It should pop right off. Some sort of rust penetration oil on the hub will help.
