I pulled the clutch off the 8 this weekend, and discovered as I expected, either the fly or the pressure plate has a significant high spot. Clutch had been chattering like crazy letting her out from a stop. Since the trans is out, I figured I send the p plate to KEP and have it checked out. When I pulled off the plate, both the p plate and the fly are very dark blue, and the disk is very smooth and hard, so she has obviously been slipping much more than I realized due to the clutch not being set up properly.
I will have the fly checked at a shop anyway, but I am curious what you guys think. The fly and the p plate both have an oval shiney spot opposite each other, where the clutch was clearly making contact first, and causing the chatter (sorry, since they are both shiney, I can't get a decent pic). Here is my Q: The spot on the fly is about 2x the size of the spot on the p plate. Does that tell you which one has the high spot?
(My guess is that makes the P plate high)
