tornik550
Nov 22 2014, 04:25 PM
I am trying to get everything in order before starting to install my 6. How do I know how high on the firewall I am supposed to install the mount? Any guidance?
Jeffs9146
Nov 22 2014, 04:28 PM
QUOTE(tornik550 @ Nov 22 2014, 02:25 PM)
I have installed one and if you pm me I will try to answer your questions. I am out of town and won't be able to send you photos until Monday
Mark Henry
Nov 22 2014, 05:24 PM
Not sure, but I imagine the bottom point sits on the seam lip. You also need to find center on the car and mount.
Before welding in in I'd attach the engine/tranny and trial fit it to see if the engine is sitting right to the seals. You can drop it about an inch if you are having clearance issues with the decklid.
Nov 22 2014, 06:34 PM
QUOTE(Mark Henry @ Nov 22 2014, 03:24 PM)
Before welding mine (RJ mount, same concept, different vendor), we did a test fit first before we committed to welding the firewall mount.
roblav1
Nov 22 2014, 08:34 PM
Mine is a Johnson unit... instead of a pre-install, I measured everything to see where I wanted it and decided to weld it as low as it will go - the bottom is right at the seam lip of the pan. The 3.6 intake is pretty tall, so I'm glad I welded it there.
SLITS
Nov 23 2014, 08:02 AM
I have used two of his mounts.
For CIS motors, I set the mount at 6 1/2" above the body seam.
For carbs / MFI I set the mount at 7" above the body seam.
tornik550
Nov 23 2014, 08:39 AM
QUOTE(SLITS @ Nov 23 2014, 09:02 AM)
I correct in assuming that we are talking about mounting the TOP of the mount at 7"? It seems obvious that is what you are saying however I want to make sure.
Mark Henry
Nov 23 2014, 08:53 AM
What rubber mounts are you using?
The ones on maddogs site look like sporto's which are a hell of a lot shorter and harder than the OEM 911 engine mounts. This can make a major difference in your install height.
It would be easy enough to add washers to make up for the sporto shortness but you couldn't go the other way around.
I find the sporto's very hard and they could transmit more noise and vibration compared to the stock OEM mount. I going to try stock mounts on front and sporto's on the rear (trans).
Edit it's not as much as I thought, around a 1/4". I'd add a thick 1/4" washer between the rubber mount and crossbar.
BTW adding a few washers between the rubber mount and crossbar would make it a bit adjustable in case you were slightly cocked off level or a bit high.
SLITS
Nov 23 2014, 09:10 AM
QUOTE(tornik550 @ Nov 23 2014, 06:39 AM)
Yes ...........
The dimension of 7" came from Rich Johnson & his mount, of which I have used 3 of his.
Mark Henry
Nov 23 2014, 09:14 AM
BTW I know all this because I just made my mount this weekend, I believe the plans were copied off a RJ 1st generation mount.
I did a few modifications to the plans, mostly to clear stuff like the wiring. One thing is I never looked at the present RJ or MD mounts, this one I made is a lot heavier/stout.
Krieger
Nov 23 2014, 09:24 AM
Are there no mounting instructions from Maddog?
SLITS
Nov 23 2014, 09:27 AM
First one done in 2007. Car was a '70 that I put a 2.4L into. Note: I didn't say I could weld, but I stuck it!!!! Ground a bit of metal here and there to get the fit I wanted.
tornik550
Nov 23 2014, 09:38 AM
All I saw as far as mounting instructions was to bolt the mount in as a trial fit then weld away after the trial.
Here are the mounts that I got with the kit. Are the stock or sport?
SLITS
Nov 23 2014, 09:53 AM
They look like sports to me. I use them without regard to their depth.
I never bolted the engine mount in in any of the cars I have done. Marked off where the mount should be (center line of car & height I wanted it) and then tacked it in place. Went back over as I was satisfied and splattered the rest of the welds.
Luke M
Nov 23 2014, 10:19 AM
tornik550
Nov 23 2014, 10:35 AM
QUOTE(Luke M @ Nov 23 2014, 11:19 AM)
Oops
Nov 23 2014, 01:21 PM
Jeffs9146
Nov 23 2014, 01:45 PM
I am on someone else's computer (MAC) and I have no idea how to copy into a thread but you can find my thread by doing a search "maddog +mount" and search by jeffs9146 posts only. You will find a complete thread with me going through all the same questions you are asking.
