Maltese Falcon
Nov 23 2014, 02:11 PM
Like the question ...is this do able, anyone here tried it?
The specs seem to be similar to the 9146 + 911s, at 108mm outer dia., 28 splines. Maybe the bearing dia. is the difference.
Marty
914Sixer
Nov 23 2014, 05:22 PM
Stub is too long if I remember correctly. Bearing is 5 mm larger I think.
pcar916
Nov 24 2014, 01:31 PM
Yes. You can use 930 output-flanges in the transaxle and early 930-stub axles in the trailing arms. I ran them for a time using a spacer so the 911 axle was long enough to reach 914 dimensions.
Eventually I changed to 100mm, 944 cv's and early 911 flanges and stub-axles. Why you ask?
1. The 3.6 puts out less than 400hp.
2. I don't need the 930's huge deflection angle on a 914... might on an off-road machine.
3. The 930 running-gear weighs a TON. Normally I shy away from non-exact descriptions,but I simply I don't remember the relative weights, but it's many pounds more than the 911/944 solution.
Good luck
Maltese Falcon
Nov 24 2014, 06:47 PM
That is easy enough to source, and I can have the axles (high strength 300m) made to spec length. I am running a flipped trans so there is an increase in the deflection angle. Weight is not an issue with this build.
I'll get some calls made+ start building after the holidays.
Thanks for the tips guys !
Marty
Maltese Falcon
Nov 24 2014, 06:57 PM
300m axles
Lobro race prep 930 cv joints, 26° operational angle
Click to view attachment Click to view attachment
Mike Bellis
Nov 24 2014, 07:34 PM
I'm running 108mm stubs with chrome moly, 28 spline axles and 40° 930 CV's. It's a tight fit but not a problem.
r_towle
Nov 24 2014, 07:49 PM
Dude, post up some progress pics already....been sitting here waiting for it....
Maltese Falcon
Nov 24 2014, 08:10 PM
QUOTE(r_towle @ Nov 24 2014, 05:49 PM)
The drivetrain; Cayene v8 +996 gt2 now mated . Might be the first of its kind on the planet.
The rest of the progress pics are here on the world:
Porsche 914-8 GTT
Marty
iamchappy
Nov 24 2014, 08:55 PM
You are totally insane.........
Maltese Falcon
Nov 24 2014, 10:29 PM
QUOTE(iamchappy @ Nov 24 2014, 06:55 PM)
Chap...big engines and big boost are nothing new for you and me
pcar916
Nov 27 2014, 06:36 AM
Very cool!
EdwardBlume
Nov 27 2014, 07:55 AM
Holy smokes Batman!
914Sixer
Nov 27 2014, 08:39 PM
Are you going to need a pilots license to fly that combo?
Maltese Falcon
Nov 28 2014, 12:07 AM
QUOTE(914Sixer @ Nov 27 2014, 06:39 PM)
I think that the APR gt-1000 rear wing, 1650 lbs. down force at 160 mph should help to keep her planted. If not I can hire Elliot for some barnstormin ! ¡
