QUOTE(DavidSweden @ Nov 23 2014, 04:55 PM)
I am going to press off the crank and timing gear.
Many of you have done this before, this is my first time. I have seen this in the manual, is it as easy as it looks.
Do I need any advice?
David
It is very easy, just be sure to remove the locking ring the distributor drive gear and the spacer. Support the gear fully and then press the crank out of it. Don't let the crank fall when it comes out
