Happy Wednesday. Since I am taking a half day from work I figured I would work on my car and try to figure out why the idle is not able to go below 1100 rpm without the car dying.
I narrowed it down to what I think is a worn out throttle body. I have purchased a used one from Bruce and it is on its way but I wanted to know how to tell exactly how much tolerance there is in a throttle body.
I have attached a number of photos showing how much light goes threw the throttle body from both directions. Not sure if I should see any light at all. Also the rod that the butterfly is attached to also has lots of play and I tried to show in the pictures as well. Any advice would be helpful.
I have read you can possibly save the life of these for a little while using JB weld and not sure if anybody has had much luck.
