JoeDees
Nov 28 2014, 10:56 AM
Decided not to build a big engine so I'm selling this stuff I picked up in a big parts lot. The 103mm JE pistons and cylinders are brand new but missing wrist pins and have minor dings on head side of one of the cylinders. $400
I also have a 2.0L block with innards and pistons/rods, fan, oil cooler with a GA serial number for $250.
Located in Norman, OK. Will sell the lot for $500 together or trade the Ps and Cs for brand new 1.7L 90mm domed P/C set.
Link to my Flickr album with more pics:
https://www.flickr.com/photos/123732647@N02...57649500001902/
JoeDees
Nov 28 2014, 10:57 AM
I should mention that I prefer cash and would rather not ship, but arrangements could be made with a good offer.
JoeDees
Nov 30 2014, 03:51 PM
Had a request for more pics.
JoeDees
Nov 30 2014, 03:53 PM
More Pics
JoeDees
Dec 4 2014, 08:56 AM
Bump
Any offers?
DRPHIL914
Dec 4 2014, 10:14 AM
QUOTE(DirtyCossack @ Dec 4 2014, 09:56 AM)
Bump
Any offers?
what displacement would these result in when put with a 2.0 motor?i have a '75 2.0L stock motor that will need rebuilding and have been considering my options for staying with F,I but getting a bit more HP. also what additional work would be required? since the heads would be worked any way what modifications wold be required to the heads to fit these?
Phil
VWTortuga336
Dec 4 2014, 11:58 AM
Assuming your 2.0L has the stock 71mm stroke crank, you would be at 2366cc. I would think the case will have to be machined to accommodate the larger cylinder OD and the heads will have to be flycut to the larger diameter as well.
JoeDees
Dec 4 2014, 12:33 PM
Yeah, it would make a 2366cc with the 71mm stroke. As far as I know machining the case and heads is necessary, and the heads may need bigger valves. I've also read that going dual carbs is helpful to attaining maximum hp and performance.
koozy
Dec 6 2014, 04:51 PM
Sending PM on the P&C set
vinniedatorch
Dec 7 2014, 10:53 AM
next in line on the entire package
vinniedatorch
Dec 7 2014, 10:55 AM
JoeDees
Dec 14 2014, 01:14 PM
Try and bump this again. Let's work out a deal. Army says I need to move soon and I need to pare down the collection. I also want some money to put into my car. haha
JoeDees
Dec 18 2014, 02:45 PM
Pistons and cylinders are sold, and engine block may be pending.
