QUOTE(stevegm @ Nov 30 2014, 04:06 AM)
I asked John Forbes (Black Forest Racing) about this today. He said that he hasn't seen any indication that the current gasoline is causing any issues on engines, including the valves. The only thing he said that might be an issue is whether the car has a catalytic converter, and what type of fuel it was designed for.
Since they have introduced ethanol in fuel here (now 10%) Im on my 2nd set of fuel hoses on the 911 since it was restored in 2008 and the engine bay hoses in the 914 once. I'm using the original cloth style hose and I don't think Wurth or whoever makes it is has changed the formula to resist it being eaten away
The hose lifetime seems to be 5 years max, after that they will start to leak and you should plan to change them as a maintenance item unless you want to risk a fire
My brother has a small block cobra replica and as I speak its in my garage waiting for new diaphragms to arrive for the Holly - totally lunched
Ethanol is not good in my book
General blurb about what ethanol can do to older cars
http://www.groups.tr-register.co.uk/wessex...nol-update.html
