Started to smell gas every time I came back in from a drive. Garage really got smelly.
So I look under the car and there is a small pool of dirty gas on the left front side, just about under the brake master.
I didn't want to mess with a fuel leak, so I drained out what gas I could and pulled the tank.
All connections seemed OK, but the stupid plastic fuel filter was wet with gas. I didn't see any signs that it came from either hose end, it almost seemed like it was weeping out. There did seem to be what looked like stress lines on one side of the filter.
I took it out, put a fresh hose on one end and plugged the other and tried to blow into the filter (using only my lungs) to see if I could see if the thing was leaking, but nothing.
I know the return pressure is high, but I don't think the intake is.
Anyway, I have a new (also plastic) filter, but was wondering if
a) anyone ever hear of such a thing?
b) is there a better filter I can use?
BTW - I guess it is possible that I overlooked a possible bad hose connection on the filter, I'm not sure. The hoses are new - and are similar to what was "original" - fiber wrapped. They did not seem to be wet - just the filter itself was wet. ODD.
Thanks,
Len
