I have a large collection of vintage VDO 52mm gauges. These were made in the late 70's to early 80's. They have the steel cases and glass lenses. The paint they used then was better and does not fade like the later ones.
I have oil pressure in 1-10 Bar and 1-10 kp/cm. Some have greeen leters
Oil temp 50-150 C and 120-300 F
Voltage 8-16
Amps + - 80 and + - 30
I have some wire harnesses with plugs which I will include
Some sending units for the pressure and temp gauges. $10 for single pole pressure senders and $5 for temp senders.
Asking $25 for each gauge or 2 for $45, 3 for $60.
The fog appearance of the lens is mainly do to the flash and reflection. Some are better than other and I will pick the best ones first.
These are 52mm and smaller than the console gauges which are 65mm.
