i have had a perma tune 911 model in my 73 914 2.0 for over 10 years with no problems.
this was installed by the mechanic who rebuilt the engine
still has points and a coil and original fuel inj.
backstory is the 914 was in storage for the winter and the battery was dead when i went to pick it up.
started right up with a jump and drove it home
about 100 yards from home it went totally dead but i was able to coast into the driveway.
would not crank-battery dead
battery would not take a charge from 120v charger
so it seems the car was running on the voltage from the alternator and something must have popped from overvoltage?
after installing a new battery, i tried a new coil (Bosche Blue)and still no luck
permatune has a troubleshooting guide and i had good results on all tests but one
"pin B to C wants 100 ohms (+ - 1 Ohm)" I had 104 ohms ( 1 ohm is a super tight tolerance)
these are expensive units and before purchasing a new unit, i would like to see if anyone know of a shop that could test and maybe repair this unit
thanks for any advice andy
