DougC
Feb 2 2005, 10:25 AM
Got a line on a Tach from a '71 911T...will that be what I need?
Doug C
BigD9146gt
Feb 2 2005, 10:28 AM
What motor, fuel supply (injection/carbs) do you have?????
DougC
Feb 2 2005, 10:34 AM
Don't have a motor yet, let alone a fuel supply (LOL), basically trying to collect all the Six conversion pieces while waiting for a good deal on an engine to pop up. You know of one? Will the engine determine which tach I need? Thanks ..
Doug C
BigD9146gt
Feb 2 2005, 11:28 AM
It really depends on the engine your going with... All the 911T with carbs and the 914-6 are the same. The impulse signal is the same. It gets tricky when you get to the CIS engines in ~'73/'74. Then i cannot say with certenty. But, with the 3.2 i know gets its signal from the motronic brain. I'd wait till you get the motor, cause a used tach isn't all that expensive. North Hollywood Speedo does conversions for tachs, so if you want a vintage tach with a 3.2 inner workings, your gonna have to folk over the dough...
Hope that helps, Don.
DougC
Feb 2 2005, 11:37 AM
Thanks for the advice, I may go ahead and pick up the 911T tach anyway since it's only $35 then resale it if I go with a larger engine.
Doug C
Root_Werks
Feb 2 2005, 11:57 AM
To get even a little more detailed:
Tachs with regular points ign thru 3 pin CD boxes
Tachs with 6 pin CD box
That is pretty much how they are divided up through 89' I believe.
3 pin CD's were used through the 2.7 series and the 3.0's were the first to use the 6 pin.
