lostreasure
Dec 11 2014, 12:08 PM
Wow any tricks getting it out? all lines removed but still not enough room to pull out from quater panel-Any advice would be greatly appreciated
Mark Henry
Dec 11 2014, 12:10 PM
You do have the oil filter console off...right?
It's held on with allen bolts.
Maltese Falcon
Dec 11 2014, 12:34 PM
QUOTE(Mark Henry @ Dec 11 2014, 10:10 AM)
+1
Remove the filter console, tap tap, slide out, ez job !
GeorgeRud
Dec 11 2014, 01:17 PM
I'd recommend doing something to close off the openings while removal or installation so dirt doesn't drop into the tank.
toolguy
Dec 11 2014, 02:16 PM
It's not an easy job but it will slide out when all the stars are aligned. .IIRC, it involved rotating the
tank and sliding as well . . hardest part is the 3 retaining studs sticking. .
I placed a very thin sheet of heavy duty vinyl between the fender and both the tank sides to facilitate
easier sliding. .
Luke M
Dec 11 2014, 08:44 PM
Also don't forget the jam nut at the lower fitting.
(in red circle on pic)
When I removed my oil tank from my factory 6 it had one on it.
6freak
Dec 12 2014, 08:44 AM
loosen rocker panel and prop it out with a small piece of wood or something ,that give you the extra 1" you need .its not hard but it does have to be in just the right position..
lostreasure
Dec 12 2014, 01:38 PM
Thanks for the help! Im going to give it another try this weekend! This had to be a afterthought for the 914 lol
lostreasure
Dec 12 2014, 04:10 PM
Do the retaining studs need to be removed?
toolguy
Dec 12 2014, 04:19 PM
QUOTE(lostreasure @ Dec 12 2014, 02:10 PM)
They are made into the tank. . not removable
patssle
Dec 12 2014, 04:58 PM
Thankfully I got the Vellios tank for my conversion - no studs. It was very easy to put in!
vintage914racer
Dec 13 2014, 01:27 AM
I just installed mine. Remove the oil filter console and it should be significantly easier
gms
Dec 13 2014, 01:16 PM
Put flares on the car and it goes much easier
brp986s
Dec 13 2014, 01:54 PM
The real job from hell is putting it back in. Due to the wide construction tolerances of the time, the tank can get wedged and stuck between the qtr and the body as you try to install it. And I don't recommend using a finger as a forward guide to locate the hole in the body for the breather spout. Your finger and the spout can actually occupy the hole at the same time, but not comfortably. I mean, so I'm told. Not me, ofcourse.
lostreasure
Dec 13 2014, 07:28 PM
Wow -not looking forward to putting it back in! Thanks again
