QUOTE(malcolm2 @ Dec 11 2014, 09:06 PM)
QUOTE(john_f @ Dec 11 2014, 02:56 PM)
Have located one unused OE CV joint but need another.
Several vendors here have taken the type 1 VW CV joint and modified it to work with our type 4 cars.
I bought mine from Tangerine Racing. PMB Performance has a similar product. I bet there are others out there. I called Chris at Tangerine and he told me all about his product and how long and how much R&D he has put into his. PMB has a similar story about their R&D.
You can probably use varying brands on each end of a half shaft. I have one OE shaft (or at least PO) and one with 2 new Tangerine CVs. Are you sure you have an OE (are you sure it is VW, they don't make them anymore).
Good luck with it.
Clark
Hi Clark,
Thanks for the info - I am aware of PMB & Tangerine Racing's products & am seriously considering them (as well as Pelican's offer of a complete replacement transaxle unit).
The OE CV joint I have been offered in the UK was purchased some years ago by the vendor & it is still in its original packaging but is surplus to the current owner's requirements.
If I've found one in the UK (where there are hardly any 914s), chances are that there must be a good few lying around in the US. If I get no response then I'll go for one of the after market examples.
Thanks very much for your help.
Kind regards,
John.
