1971cc Type IV case line bored, shuffle pinned, drilled and tapped oil passages ( work done by RIMCO ) High volume oil pump 914 2.0 crank machined to rabbit journals. 71mm stroke Rabbit rods CIMA 94mm flat top pistons Mahle 94mm barrels with sp [...]
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
