QUOTE(Cuda911 @ Dec 22 2014, 03:17 AM)
1973 1.7, FI.
The car starts up fine, and runs perfectly when cold. Idle is at about 1,100 or so, However, after driving for maybe 30 min. and everything's fully warmed up, the car stalls when stopped, like at a traffic light. The idle drops way down, then stalls out.
It will start right back up no problem, but makes stop-and-go driving a rather harrowing experience. I need to heel-toe it every time I slow down, to keep the RPMs up and prevent a stall.
Pretty much everything on the car is stock.
What should I be looking at to address this?
I did some searches, and the three things I came up with are Manifold Pressure Sensor (MPS), Cylinder Head Temperature Sensor (CHTS), and points.
Please note, I'm a noob at working on this car, so please provide specific details, if possible.
Thanks in advance.
Hi Mike,
Sounds like its running too rich. When the car is cold it "likes" that condition and won't display symptoms, but as it warms up it does not. I assume you've been all over
Anders' D-Jet site, right? Did something change suddenly or over time? I would check:
1. Fuel pressure at FI rail with gauge (should be ~28 psi)
2. Points condition and dwell (should be 45 to 50 degrees)
3. CHT resistance both hot and cold (can't remember normal values off top of my head - doesn't sound like the CHT is completely bad but could be going in that direction; when completely bad car will die after 5 or 10 minutes tops)
4. Air intake temp sensor to make sure it's connected and giving good resistance readings (it's under the air cleaner, top / back of engine -- two wires going to it)
5. The MPS - check electrical connection, resistance values between terminals, and ability to hold a vacuum at the port (buy a little vacuum pump)
6. Trigger point connection solidly connected at back of dizzy.
I suppose it could be the cold start valve too, but I have no experience with that and I would think that would flood the engine more quickly. Eliminate the variables you can with the tools/knowledge you have and then ask for more help. Because the car still runs I would think the MPS and CHT haven't failed, at least not completely.
I'm sure you'll get a ton of additional input here that's more useful/informed than mine, but hopefully this helps.
rc
