Type4 store rocker arm spacer and shim arraignment. Does the picture look correct?
Is there no shim or washer between the inner side of the rocker shaft mount and the outer side of the rocker arm, wouldn't this be a high wear area?
How tight should this assembly when installed?
Thanks. Click to view attachment
