QUOTE(potomacmidget @ Dec 28 2014, 10:15 PM)
Hi All,
Looking for a door switch for my 71, 914. Looking for the switch that works the interior light.
thanks in advance,
Reg Kidd
I will defer to Jeff's knowledge, I guess I need the 4 pole -as I have a 1971 car. The current switch won't work the light, and I found that a prior owner had cut away some wire insulation to indeed verify that the switch was getting power (I did the same thing and then accidentially shorted the wire and luckily only blew the fuse. I am guessing the switch is bad and am willing to give another switch a try. Any advice on removing the switch? It seems particularly tight in there.
thanks,
Reg
