Mueller
Feb 3 2005, 07:27 PM
okay...for a factory 914 /4, the front calipers (piston
area wise) are 1.61 larger than the rear....(42mm and 33mm)
for early 911's (up to '84), the fronts are 1.6 larger
from '84 to '89, the fronts are only 1.3 times larger than the rears....then the ratios vary from 1.4 to 1.7 until the arrival of the 1st Twin-turbo, that car has calipers that have piston areas 2X the size of the rears !!!!!
I'm just wondering what combo people have successfully ran.....it's interesting to note that the standard Boxster front calipers if bolted to the front of a 911, the Boxster piston area is only 1.05 larger than the standard 911 fronts.....seems like a darn near equal swap, except for the bigger pads you get with the Boxster calipers
bd1308
Feb 3 2005, 07:28 PM
um...stock? I'm gonna wait till my rears rust and reak off
Feb 3 2005, 07:58 PM
QUOTE (Mueller @ Feb 3 2005, 05:27 PM) |
I'm just wondering what combo people have successfully ran |
'84/'85 carrera on all 4 corners ... the fronts in the front and the rears in the rear ...
Andy
d914
Feb 3 2005, 08:02 PM
944 turbo front
carrera rears
Mueller
Feb 3 2005, 08:04 PM
QUOTE (SirAndy @ Feb 3 2005, 06:58 PM) |
QUOTE (Mueller @ Feb 3 2005, 05:27 PM) | I'm just wondering what combo people have successfully ran |
Andy |
so you have option 4.....
i'm trying to figure out what I am going to do for rear calipers.....I've got 4 calipers that are 6% larger than the Boxster front calipers....
I was thinking that I could modify the rears so that only one piston per side was used, but I don't know if the rear calipers would ever work even with an adjustable prop. valve?
Feb 3 2005, 08:12 PM
QUOTE (Mueller @ Feb 3 2005, 06:04 PM) |
I don't know if the rear calipers would ever work even with an adjustable prop. valve? |
don't know about the one piston thing but i can tell you that, unless you change your complete braking system, a adjusteable prop-valve is wasted money. you'll end up running it full open anyways. that's why i used a "T" instead ...
Andy
Eric_Shea
Feb 16 2005, 09:58 AM
S-Caliper
M-Caliper
T-Fitting
I just went off the hp rating the factory had with the 76 930 (240) and installed that system. I'm planning on my 2.5 S engine to be close to that. (220-240 range)
JmuRiz
Feb 16 2005, 10:19 AM
Front - 4 piston Brembo monoblocks
Rear - Stock with 914/6 rotors
Replaced the prop valve with a 'T'
bondo
Feb 16 2005, 10:25 AM
I have the second option, but I can't tell you how it works because my car is still a pile of parts. I will be using it with a 19mm master cylinder and a tee in place of the prop valve.
don9146
Feb 16 2005, 11:00 AM
I have 964 front calipers clamping cross-drilled and slotted rotors in the front, stock calipers in the rear, a 19mm master cylinder, and the brake line "T" replacing the proportioning valve. Balance and feel are excellent with no fade on open track day events.
fiid
Feb 16 2005, 11:25 AM
Friction is a function of normal force, not of surface area.... so it is just the piston size that matters, not the pad area. (
http://www.school-for-champions.com/scienc...ce/friction.htm )
I would be a little careful about using the 911 ratios as too much of a data point since their weight distibution is probably a little different (wrong) compared to the 914. The MR2, Elise, Europa, Esprit, X1/9, Ferarri 360 (engine is a little heavy here) might be more interesting though.....
It seems like it is possible to correcly balance everything up to and including A calipers on the front with the stock 914 rears - which is what I am doing. If I were you - I'd probably just go to M calipers....
Don't forget - the other way to increase braking is to reduce weight..... Perhaps some fibreglass decklids would help :-)
Mueller: Sorry for abrubtly ending the phone call - I'll call you back today sometime... I had to do a demo for the board.
ArtechnikA
Feb 16 2005, 11:29 AM
'S' calipers front, widened 914.6 calipers rear.
v82go
Feb 16 2005, 11:36 AM
Front= M (911)
Rear=stock (redrilled/5lug)
Prop. valve replaced witha "T"
bondo
Feb 16 2005, 11:51 AM
QUOTE (fiid @ Feb 16 2005, 10:25 AM) |
Friction is a function of normal force, not of surface area.... so it is just the piston size that matters, not the pad area. |
I bet pad area affects heat accumulation to some degree. It also definitely affects wear rate. One thing that is certainly a factor is rotor diameter.
That page mentions that surface area comes into play when material deformation occurs. I wonder if pads deform enough? It'd be interesting to do some experiments in a real world situation.. do some repeated hard braking, then cut away half the pad area and do it again
fiid
Feb 16 2005, 12:13 PM
I think you hit the nail on the head.
Pad area would effect wear rate, and I bet it has some thermal effects too - like felxing you mentioned.
If you assume that the braking force originates (on average) from the center of the pad, then a bigger pad and larger radius rotor whould also move the braking force further out, giving it a greater mechanical advantage (of course - larger tire radius would lose you this battle from the other end)....
fiid
Feb 16 2005, 12:14 PM
felxing is the combination of felching and flexing, which happens when you get small animals caught in your brakes.
anthony
Feb 16 2005, 12:17 PM
QUOTE (Mueller @ Feb 3 2005, 06:27 PM) |
okay...for a factory 914 /4, the front calipers (piston area wise) are 1.61 larger than the rear....(42mm and 33mm) |
Does this ratio take into account the proportioning valve? It must change the "ratio" in the stock system. Most people, when they add 911 front brakes, remove the proportioning valve to make the rear brakes work more.
1973914
Feb 16 2005, 12:23 PM
Boxster Monoblocks up front/Vented rotors
Carrera M (Wide) Rear/Vented rotors
T in place of rear slave cylinder
Monoblocks have light weight with minimal flex. Think of the S calipers but stronger. No prop valve (although i may add one just in case). This of course for 5 lug, but they fit under the 15's.
bondo
Feb 16 2005, 12:44 PM
QUOTE (fiid @ Feb 16 2005, 11:13 AM) |
If you assume that the braking force originates (on average) from the center of the pad, then a bigger pad and larger radius rotor whould also move the braking force further out, giving it a greater mechanical advantage (of course - larger tire radius would lose you this battle from the other end).... |
Now that I think about it, pad area and heat MUST be very related. If friction is the same for a smaller pad (or nearly the same), the amount of heat energy must also be the same, because dynamic friction is simply the conversion of mechanical energy to heat. So that same amount of heat would be concentrated on a smaller pad area and overheating it sooner.
I guess the same thing would apply to clutches. Too bad our bellhousings are so darn small.
ArtechnikA
Feb 16 2005, 12:59 PM
QUOTE (anthony @ Feb 16 2005, 01:17 PM) |
Most people, when they add 911 front brakes, remove the proportioning valve to make the rear brakes work more. |
in my case, i removed the proportioning valve because after changing the caliper piston ratios, it was no longer needed.
QUOTE |
Too bad our bellhousings are so darn small. |
go have a look at a Tilton or F1 clutch :-)
fiid
Feb 16 2005, 01:06 PM
QUOTE (bondo @ Feb 16 2005, 10:44 AM) |
QUOTE (fiid @ Feb 16 2005, 11:13 AM) | I think you hit the nail on the head.
I guess the same thing would apply to clutches. Too bad our bellhousings are so darn small. |
what you said.
lapuwali
Feb 16 2005, 01:28 PM
QUOTE (fiid @ Feb 16 2005, 11:06 AM) |
QUOTE (bondo @ Feb 16 2005, 10:44 AM) | QUOTE (fiid @ Feb 16 2005, 11:13 AM) | I think you hit the nail on the head.
what you said. |
Thanks. I've been saying this for YEARS, and no one listens, since pad area is "obviously" related to braking power.
Yes, pad area primarily affects pad wear. It can also bring on fade if the pads are small enough that they get so hot their coefficient of friction falls. By itself, pad area has NO effect on clamping force or braking effectiveness.
I'd also hesitate in quoting 911 brake balance figures when talking about 914s. Static weight distribution definitely matters. I'd use Boxster figures, though, with a small grain of salt. Remember that the height of the CG also comes into play, since it affects weight transfer rear to front under braking. A lowered car needs less frontward brake bias than a car with stock ride height, as less weight will transfer forward under braking, so the rear brakes can contribute more to stopping.
Andy
Feb 16 2005, 02:11 PM
Then I better hold off on the wide slicks and keep my 55 series for taking the 914 to the track!
Just kidding, friction is independant of surface area using the "standard model" which is a simplified system that is pretty far from covering all examples, it does work for most, but for more extreme examples, like tires, it is no longer accurate. This is kind of a pet peeve of mine as most teachers simply teach the standard model and state that it's just counter-intutive and leave it at that, often not even knowing that they're misleading people. I'm not saying that in case of brake pads the standard model would give inaccurate data. In most cases friction is independant of surface area.
Can you tell I work in higher education?
http://hyperphysics.phy-astr.gsu.edu/hbase/frict3.html
lapuwali
Feb 16 2005, 03:20 PM
QUOTE (Andy @ Feb 16 2005, 12:11 PM) |
http://hyperphysics.phy-astr.gsu.edu/hbase/frict3.html |
True enough. Tires don't use the "classic" friction model usually taught in school. Brakes, however, do. Indeed, brakes are nearly the ideal thing to use to teach the classic friction model, since all of the effects are present: coefficient of friction, lubrication effects, heat effects. In also somewhat decouples the the mass v. weight issue, since people learning basic physics often confuse overcoming inertia with overcoming friction when taught using the normal "pushing a big stone block" technique.
Tires are so complex it's pretty hard to teach how they really work in a basic physics course.
fiid
Feb 16 2005, 03:23 PM
thanks! I was wondering about the tire case.
lapuwali
Feb 16 2005, 05:05 PM
QUOTE (fiid @ Feb 16 2005, 01:23 PM) |
thanks! I was wondering about the tire case. |
I've never thought of a good tire analogy. Tires somewhat interlock with the surface, and they seem to employ some qualities of actual adhesives. I've had fresh physics majors insist no one can ever exceed 1.0G in a turn because that would mean the coefficient of friction would have to be higher than 1.0, which is "impossible". You can show them all the data in the world showing that modern slicks top out at about 1.3G on a good surface, and they won't believe it. Of course, bees can't fly, either...
Mueller
Feb 16 2005, 05:32 PM
speaking of pads....from what I have read, if you have 2 different calipers, 1 with 2 pads and the other caliper has 4 smaller pads which equal the sq. inch surface area of the 2 pad caliper, the 4 pad caliper will be more effiecient..it is due to the 4 pad caliper having more "leading edges"
Andyrew
Feb 16 2005, 05:35 PM
I kinda want to put 944 turbo calipers on, then 914 fronts on the back... (or something like that...) but I really want to be able to have a hand brake...
944 turbo's put the same on the front as they did on the back, and those things stop like a mother!!! (especially with some sticky street tires... aka my street race 205's...)
something to keep in mind...
Mueller
Feb 16 2005, 05:39 PM
QUOTE (Andyrew @ Feb 16 2005, 04:35 PM) |
something to keep in mind... |
simple...get the parts from an early 911...(I'd think the 944 parking brake is very similar)...only downside is you have to pop-off the wheel hub unless you get creative and make it bolt on differently
Mueller
Feb 16 2005, 05:41 PM
are you sure the calipers are the same? I know they use the same size pads, but the pistons might be smaller in the rear.....
lapuwali
Feb 16 2005, 05:59 PM
QUOTE (Mueller @ Feb 16 2005, 03:32 PM) |
speaking of pads....from what I have read, if you have 2 different calipers, 1 with 2 pads and the other caliper has 4 smaller pads which equal the sq. inch surface area of the 2 pad caliper, the 4 pad caliper will be more effiecient..it is due to the 4 pad caliper having more "leading edges" |
Never heard of that. Can't think of any reason for improved "efficiency" (whatever that's supposed to mean) with more than one pad per side. I've seen such arrangements, and the best story I heard was it allows you to compensate for the unequal wear between the leading and trailing edges of one large pad by simply replacing one of N smaller pads, all of which are the same. On some early 6 or even 8 piston calipers, I've seen setups with a small round pad per piston.
Another way I've seen to attempt to solve this is to stagger the size of the pistons so the leading edge pistons are smaller, and thus exert less force than the trailing edge pistons. I've seen two-piston slider type (pistons on the same side with a slider "claw" on the other), four-piston, and six-piston calipers made this way. One saw this a lot on bikes a few years ago, and may still today for all I know. Still one pad per side, but presumably it didn't taper so much, and wore more evenly.
Perhaps it's "cost" efficiency? Replace only the rapidly wearing leading edge pads, not the whole pair of (presumably tapered) pads?
Andyrew
Feb 16 2005, 06:36 PM
Dad doesnt think theres any difference in the front or the rear..
I might look into that rear parking brake system...
hmm..
bondo
Feb 16 2005, 07:00 PM
QUOTE (lapuwali @ Feb 16 2005, 04:59 PM) |
QUOTE (Mueller @ Feb 16 2005, 03:32 PM) | speaking of pads....from what I have read, if you have 2 different calipers, 1 with 2 pads and the other caliper has 4 smaller pads which equal the sq. inch surface area of the 2 pad caliper, the 4 pad caliper will be more effiecient..it is due to the 4 pad caliper having more "leading edges" |
Perhaps it's "cost" efficiency? Replace only the rapidly wearing leading edge pads, not the whole pair of (presumably tapered) pads? |
Hmm, interesting.. I wonder if this could have anything to do with why some pads have a slot in them (probably not) Maybe it's just a wear indicator.. but that wouldn't make much sense either unless you remembered there was a slot there when you installed the pads.
fiid
Feb 16 2005, 07:40 PM
QUOTE (lapuwali @ Feb 16 2005, 03:05 PM) |
QUOTE (fiid @ Feb 16 2005, 01:23 PM) | thanks! I was wondering about the tire case. |
I've never thought of a good tire analogy. Tires somewhat interlock with the surface, and they seem to employ some qualities of actual adhesives. I've had fresh physics majors insist no one can ever exceed 1.0G in a turn because that would mean the coefficient of friction would have to be higher than 1.0, which is "impossible". You can show them all the data in the world showing that modern slicks top out at about 1.3G on a good surface, and they won't believe it. Of course, bees can't fly, either... |
They must be adhesive since slicks will actually pull gravel out of a poorly bonded surface.
The other assumption that might be wrong is that there is only gravity acting downwards - a well setup car will also be generating downforce which is a direct mulitplier in the friction equation.
xitspd
Feb 16 2005, 10:04 PM
Mike,
I am using a 993 Twin Turbo front on my Teeners front
xitspd
Feb 16 2005, 10:05 PM
QUOTE (xitspd @ Feb 16 2005, 08:04 PM) |
Mike,
I am using a 993 Twin Turbo front on my Teeners front |
And a 993 Twin Turbo rear on the rear with good results.
Mueller
Feb 17 2005, 12:25 AM
QUOTE (xitspd @ Feb 16 2005, 09:04 PM) |
Mike,
nice....
according to a chart I've read....the piston area of your front calipers are 2X larger than the rears ...they have the most amount of front bias than any other P-car (production)..... 2:1
love your car
neo914-6
Feb 17 2005, 02:00 AM
Bill ran this on his track car, now Neo914...
911T Front Struts / Vented Discs / Calipers with Porterfield R4 brake pads
23mm Front Torsion Bars
Front Brake Ducting
944S Rear Vented Discs / Calipers with Porterfield R4 brake pads
19mm Master Cylinder
Cockpit Adjustable Brake Bias Valve
seanery
Feb 17 2005, 02:08 AM
my upgraded car has 951 calipers front boxster calipers in the rear with (I think I remember) Carrera front rotors and SC rears.
seanery
Feb 17 2005, 02:12 AM
here's the scoop on the 951 calipers front vs rear:
The physical size of the caliper is the same and they use the same pad.
They are both 4 piston calipers, but the rears have slightly smaller pistons.
It took a while to figure it out.
the 951 fronts are great....and I think the rears would be fine on a 914...on the front
TimT
Feb 17 2005, 08:01 AM
Front: Wilwood billet superlites w 11.75x1.25 discs
Rear : Carrera calipers drilled slotted discs
Adjustable bias valve
Hawk blue pads
CptTripps
Feb 17 2005, 10:02 AM
Mine came with the BMWs on the front, stock rears, and a 19mm master.
I'll do a brake upgrade next year, but when I go to re-bleed the brakes in a few weeks, should I keep the prop-valve, or can I replace it with a T-valve? Any thoughs on settings?
