QUOTE(loonybob @ Dec 30 2014, 04:12 PM)
I have looked at plastidipping but it seems much harder and less permanent.
Not true....at all. If you put it on correctly (which is easy to do) it'll last for years.
You can get 3gal of Plastidip for $300. Wrapping your car with 3M 1080 will run you about $600...and that assumes your body is perfect and you know how to put it on. Slight imperfections are magnified with vinyl, where the PD will flow them out a little better.
I plastidipped a set of rims for my DD, and it was there until I removed it 2y later. I even had a tire-change in there and all it took was about 90sec with a rattle can and you couldn't tell where the damage was. Bonus: When I took the dip off, the rims still looked new. (Rims were on a 2013 BMW 535i)
I have 4gal of Plastidip in the garage that I was planning on doing my car with this summer.
