QUOTE(BeatNavy @ Dec 31 2014, 09:40 AM)
Ok, I found it. Yes, there is a
Relay.
In the picture above, the upper right pole is the power input. The upper left is the low setting ground. The lower one opposite, just under the power pole, is medium. And the lower left one is high. At the connector in the trunk, the power line is always hot, and moving the fan speed select switch grounds one of the three poles - upper left for slow, lower right for mid, and lower left for high speed.
For the sake of anyone else finding this via searching, there is only power on the power input (red/white wire usually) when the ignition is on and not in start.
The "blower power" relay is what's sometimes also called an "unloader" relay; it's off when starting in order to leave more power for the starter. On some cars other things are unloaded as well:
- Headlights (low and high beam, direct from the ignition switch via light switch)
- Horn (relay coil power from the blower relay)
- Wipers (run off the blower relay output)
- Headlights up (direct from ignition switch via light switch)
- Fog lights (relay coil power from ignition switch)
The starting point for all these is the smaller red wire from terminal X on the ignition switch.
