Background: First of all I live in Phoenix…cold is below 50 and I rarely drive in the cold. I had to remove the upper cylinder tins to grind a channel for cylinder head temp sensors so the area is already opened up. I don't have a thermostat or cooling flappers and I have an external cooler with 180F thermostat and 212F fan switch mounted under the rear trunk. My oil temp runs around 220F, sometimes a little warmer during prolonged high speed freeway driving.
Should I leave the oil cooler side flapper off like it is; or install a flapper and fix it in the open position to route some cooling air thru the cooler?
Thanks
