I installed an Audiovox CCS-100 Universal Cruise Control on a sport touring motorcycle, worked very well. It is an automotive unit that became very popular with motorcyclists. As long as the car has a mechanical throttle, you should be able to adapt it, it is a universal kit, it will not be plug and play, and requires some creativity in fitting everything properly.
Audiovox no longer sells this unit, but it appears that a clone from the original manufacturer is available here:
http://www.murphskits.com/product_info.php?products_id=422The CCS-100 is a vacuum based servo, if lack of vacuum is a concern you might want a vaccum reservoir as part of the system, or consider a more modern all electric alternative here:
http://www.amazon.com/Rostra-Universal-Ele...sxp_grid_pt_0_1No experience with this unit, but great reviews on Amazon, and apparently Rostra was the original manufacture of the Audiovox unit. In addition to being totally electric, it may benefit from a decade or more of technology improvements compared to a clone of the original Audiovox.
